paano ba yung connection, i have already a tachometer 4 wires, how do i connect it to the engine, if the engine is diesel
red wire = main power (ignition)
black = ground
green (tach or shiftlight) = rpm from box
in the injection pump area have 2 wires, so where to connect this?Originally Posted by SunTzu
to the tachometer?
I have no idea sa diesel na ride...pero if you have a multi tester, check mo kung alin dun sa 2 wire na binangit mo ang ground...yun ang sa black, and the other sa green wire.
I tested the sensor(injection pump) but no one is connected sa to a ground, so meaning yung isang wire baka connect to +12V and the other one is to the tachometer. ito kaya.Originally Posted by wildthing
possible din yan. Try setting the multi tester to volt (sa 50V max) and measure the voltage across the 2 wires, then one of the wires and a body ground....if you get a reading on one of the wires, yun ang live (12v+).
