Results 1 to 10 of 10
    Jul 2003
    bakit ang tagal maglabas ng tubig yung evaporator ng AC ko, marumi nakaya yung system, or meron barado sa loob nito. meron lumalabas pero konti lang. pag park ang car yun tumutulo na yung tubig sa drain hose.
    ibig sabihin nun meron ice sa evaporator. kaya pag park mo saka lang lumalabas yung water kasi nag-melt yung ice pag off na aircon. cause is either of 3 things.
    1. dirty evaporator restriciting the flow of air, thus causing the condenstae to form ice on the fins (and then causing it to become restricted even more).
    2. malfunctioning thermostat or expansion valve
    3. refrigerant charge not at required pressure, may be too low (lower evaporation pressure means lower evaporation temperature, BUT ONLY IF the heat load is still within the actual system capacity. if the load is higher then the temperature actually goes up, as in the system needs charging).
    Jul 2003
    pero malakas naman ang buga ng hangin, saan banda nakalagay ba yung expasion valve.
    Dec 2003
    expansion valve is installed on the evaporator itself...
    well tama si Yebo, pero ang pinakasimpleng papacheck ko sayo is kung naipit o nagkamali ba kabit ng drain hose. Kasi kung naipit sya kahit konti, di na free flowing ang draining.
    Jul 2003
    Quote Originally Posted by theveed
    pero pag park naman ok naman.
    bka di mo lang napapansin dhil tumatakbo ang kotse mo.
    Aug 2005
    I think correct si nizmo, baka di mo lang napapansin, pero i check mo din floor carpet mo kung basa, baka dyan napupunta yong tubig, may leak ang drain pan mo o baka nakataas yong hose jung nababasa ang carpet mo.
    try mo mag connect ng hose from evap drain to condenser. Sa condenser mo patuluin para mas efficient ang cooling effect lalo na pag traffic.
    para sa mga lumang kotse, pro un mga bago di na kailangan ksi hi efficient na un cooling
Water from AC Evaporator
