Results 1 to 6 of 6
December 5th, 2005 02:20 PM #1
paano ba yung connection, i have already a tachometer 4 wires, how do i connect it to the engine, if the engine is diesel
December 5th, 2005 02:39 PM #2
red wire = main power (ignition)
black = ground
green (tach or shiftlight) = rpm from box
December 5th, 2005 02:46 PM #3Originally Posted by SunTzu
to the tachometer?Last edited by acenie; December 5th, 2005 at 02:48 PM.
BANNED BANNED BANNED
- 3,790
December 6th, 2005 07:00 AM #4I have no idea sa diesel na ride...pero if you have a multi tester, check mo kung alin dun sa 2 wire na binangit mo ang ground...yun ang sa black, and the other sa green wire.
December 6th, 2005 09:11 AM #5Originally Posted by wildthing
- 3,790
December 6th, 2005 01:57 PM #6possible din yan. Try setting the multi tester to volt (sa 50V max) and measure the voltage across the 2 wires, then one of the wires and a body ground....if you get a reading on one of the wires, yun ang live (12v+).
high idle RPM at engine start
