Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21
    Quote Originally Posted by bogart_seph View Post
    does the sentra lec model really uses timing chain instead of timing belt?
    yup, all newer vehicles of nissan is using chains instead of belts.
    #22
    yes nissan ay t-chain..
    #23
    Toyota's 3k, 4k 5 k 7k timing chain. Mitsubishi's 4D56 - timing belt. Nissan's TD42- timing gear. Mercedes-Benz's M111-timing chain.
    May 2005
    #24
    Quote Originally Posted by alwayz_yummy View Post
    mali ka, wala pa ko nakikitang local revo na timing chain--7k is still timing belt, 1kz, 1zz, 1kd, etc.. all passenger models ng toyota uses timing belt. nissan offers timing chain talaga, from ga16, qd32, td27, sr20, etc....
    and i dont believe na makina ng avanza ay timing chain.. its practicallty the same as what the vios/echo has.....and most top-end models nga ng toyota timing belt parin...even diesl engines...
    AFAIK...timing chain ang nakalagay sa K series ng toyota
    sa REVO na diesel engine ito ang naka timing belt
  5. #25
    my bad..hehehehe...
    Jun 2006
    #26
    Medyo OT but still related.
    The following uses timing gear:
    Nissan patrol - yung fating gamit ng PSG, dont know about current version.
    Isuzu Highlander
    Isuzu Crosswind
    Kia Pregio
    #27
    does a '92 sentra JX model also uses Timing Chain?
  8. #28
    now i believe na gas engine ng revo, avanza are not timing belt...sa innova din ata...
    mostly diesels pala nalang ng toyota uses belt parin???
    ang honda civic fd timing chain na din. ewan ko lang sa bagong crv at sa ilalabas na bagong jazz
    Nov 2006
    #30
    guys, pasingit lang, ano ba pinagka iba ng timing belt at timing chain? which is better? papalitan ko narin kasi timing belt ng auto ko, (mistu galant SS 4g63 Matic 96) mga magkano po ba yung original nun? Sabi sakin nung mekaniko, mas maganda daw kung made in Japan bibilhin ko, tama ba? thanks uli!
  11. #31
    vie > bilhin mo US-brand, particularly GATES! OEM-replacement.. every 60thou or 3-4 years ang palitan nyan...
    sa liteace ko contitech brand(germany) 800 pesos (isa sa pinakamahabang t-belt ang nasa 2C ng liteace ko!
    siguro lower yan... sa price ng t-belt ko, SOHC naman yang makina na yan,e... 1000+ ang orginal part
    PS: kung tbelt na makina mo wala ka na po magagawa para gawing tchain/tgear pa yan unless palitan mo ang buong makina mo!
    #32
    yes. LEC, 1.4 JX, EX Saloon, Super Saloon Sentras all use timing chain
    Jun 2006
    #33
    Quote Originally Posted by viepink View Post
    They both have the same purpose and use. AY is correct that you can not change from tbelt to chain and viceversa without replacing the engine.
    Chain is long lasting. No need to replace unless it starts to become noisy. If your lucky it will last the life of the engine. Drawback is its noisier than belts.
    Timing belts are replaced at around 80,000 kms. Change your water pump at the same time. Some people change earlier as preventive maintenance. Cause if it breaks your engine and wallet are in for a world of hurt. Its quieter than chain.
    #34
    CHON> tnx! -galing pla ng sentra nmen! hirap p nman pgnaputulan k ng T-belt!
timing belt or timing chain?
