Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
    Feb 2004
    #21
    Quote Originally Posted by saintmichel View Post
    ah! may after market palang installable na pwoer windows? e bakt bawal ung likod?
    hindi naman po sa bawal, pero pansinin nyo po ang windows ng FX, ung front lang yung nabababa. yung sa likod e sliding.
    #22
    galing mo bro d ko napansin hahahaha sori bangag galing sa gimik e hahaha ic ano pa ba ano po ung mga common sakit ng fx? mga things to watch out tsaka tips on how to maintain?
    Jul 2006
    #23
    bisagra nung dalawang pinto sa harap. medyo sirain daw.
    Dec 2011
    #24
    hi,
    need help po
    tamarraw fx diesel 2C
    bought 2nd hand 4 yrs ago
    Usage:
    1. daily commute to ofis / day shift (aprox. 5-6 km. distance from home)
    2. city driving with minimal traffic (speed ave. 40km/hr)
    3. no extra butingting sa unit, just the stock Radio and dual aircon.
    symptoms & re-occurring issue
    1. every approx. 2-3 months, ayaw mag start, parang drained ang battery / not enough power para i-start (parang battery is not fully charged but not fully drained).
    2. bought new battery 6 months ago & new battery terminal, upgraded to Motolite excell para mas malakas daw, and did the BIG 3 connection ( made sure na grounding is ok both sa body and engine + connection from alternator to positive ng battery) same issue pa din.
    3. everytime ayaw na mag start, nilinis lng ang battery terminal and push start, ayon ok na nmn then after 2-3 months, back to the same issue.
    4. medyo may signs na it's time to clean the battery terminal (kahit na malinis ang terminal, kailangan linisin ulit otherwise, same issue) kasi humihina ang tunog ng horn, pag hindi ko nilinis, the next morning, ayon, ayaw magstart.
    Starter, glow plug & fuel supply - for me is not an issue. pag malakas ang battery, start agad.
    Grounded - for me, not an issue din /kahit maulan. kahit ilang araw hindi ginamit, start nmn agad.
    Battery terminal is always clean.
    alternator? not sure.
    charging nmn sya and normal ang charge rating pag test sa battery shop.
    could be na charging nya is not enough to compensate sa usage?
    but basic lng gamit ko, stock stereo and aircon.
    also, pag alternator, dapat hindi 2-3months kundi like weekly or even daily ang issue.
    experienced alternator isyu with my other car, i know kung alternator (on my own understanding).
    ilang shop na pinuntahan ko, sabi nila palit daw ignition starter, glow plug, battery, alternator, even ignition switch etc and etc.
    Sorry, mahaba ang post ko, detailed na po. Thank you.
    gusto ko sana ma-pinpoint kung ano ang isyu nito, ayaw kung palitan ang hindi dapat (sayang lng at magastos).
    may na experience na po bah kayo kapareho nito?
    pa-help naman po ng inputs nyo.
    Thank you in advance!
    #25
    I used to own one and I'll just share my experience with it.
    First you have to make sure the alternator is charging properly, by installing a cigarette port volt digital display to monitor it.
    13.5V- minimum voltage when alternator charging at heavy load AC and headlight on.
    15.3V-max voltage when alternator charging the battery without load, or it will blow the solution.
    If the voltage is below 12V, it will be hard for it to start.
    Second almost na-experience ko na rin lahat yung naranasan mo at nagawa ko na rin yung mga nagawa mo.
    Nung nahirapan na akong magstart lalo na sa umaga ay nirekomenda ng diesel mechanic na i-over size na daw yung piston ring.
    Hindi ko na pina compression test, dala na rin na bago pa ako sa diesel, pero naging maayos naman ang kinalabasan although later on after sometime parang nahirapan na ulit mag-start especially sa morning kaya binenta ko na at bumili na ako ng Ertiga.
    HTH.
    Dec 2011
    #26
    *Flipo - thanks for sharing ur experience
    yep, i have digital voltmeter and all readings are within range.
    (thanks for the heads-up on how to read the voltmeter, i have one but didn't know to interpret prior to reading your inputs, )
    Yes, your experience/input is a big help. It will help my future decision on what to do next.
    *love my Tamarraw FX - I have no other issues except just this start-up recurring issue.
    #27
    May redondo ba o clicking lang? kung click lang could be the starter/solenoid needs re-building.
    Kung may redondo - glow-plug, air-in-fuel line or restriction/ fuel filter.
    Other possible causes - parasitic drain, alternator not charging/busted rectifier...
    Jul 2013
    #28
    HTH.
    Based on our personal experience with the 2C (and the older 1C)
    Kapag mahirap mag start (pero kapag itulak mo magstart naman) malamang tukod/pudpod na yung valves.
    Hindi kasi pwedeng iadjust yung valve nya, so kapag luma na and napudpod na, wala kang choice but to have the engine fixed (kinalas mo na din kaya mas mabuting palitan na lahat ng dapat palitan)
    Dec 2011
    #29
    *12vdc
    clicking lng at walang redondo, ito yung isyu ko pag -ayaw mag start.
    'l take this into consideration, papacheck-up din ko yung starter/solenoid
    Thanks sa input
    Dec 2011
    #30
    thanks for sharing *ice15
    #31
    Yan din starter solenoid ang experience ko dati sa 2C and sa 4d56.
    And yes tama din yon diagnosis kung redondo ayaw tumuloy because of the nature of diesels being compression-ignition:
    - loose compression
    - valve shims/ clearance needs adjustment/replacement
    - pwede rin injection pump
    Ang Diesel kapag loose compression o singaw ang valve hirap start
    Ang gaso, agnas na ang sleeve o putol na ang ring, start pa rin.
    #32
    O yes I forget to mention nung binaba yung makina to over size the piston, the mechanic replaced the valve seal, grind and cleaned the valve, palit din ng thrust bearing, camshaft oil seal, pati na rin timing belt (Unita), and cylinder gasket.
    Quote Originally Posted by ako123456 View Post
    *12vdcalve
    Thanks sa input
    Earlier nagpalit din kami ng buong starter (rebuild from yocks electrical sa Paco).
    But despite all of these after sometime nagbalik ulit yung hard starting sa morning with my Amaron battery.
    Dec 2011
    #33
    at least na narrow down ko din ang possible cause...
    Try ko muna 'tong rebuild/new starter, baka makatulong. kung bumalik ang isyu, then it's time to consider buying another car.
    tipid tipid muna sa hirap ng buhay
    Salamat sa inyong lahat na nag share ng experience at inputs!
    Jul 2013
    #34
    Actually yung isang FX namin dati, we decided to just replace the engine with a Japanese surplus 2C.
    Mas maingay compared to the local version pero hanggang mabenta na namin yung mga FX namin di sya nag ka problema.
    #35
    Umabot din ng 5 yrs (2010-2015), yung itinagal ng pagka-over size, but I was working abroad and 2 to 3 times a year lang ako umuuwi para magamit ko although pinada-drive din ni wifey if there is a need.
    I was able to used it more in 2013 to 2015 when I retired as OFW.
    Jul 2013
    #36
    hmmm... parehong 94 model yung amin (I remember that it came out of the dealership without seatbelts
    after 5 years, parehong starting problem... Yung isa overhaul, yung isa engine replacement... nabenta na pareho bago nagloko ulit...
    Naalala ko yung kapitbahay namin, ginawa pa nyang automatic yung FX nya... Yung Japanese surplus na 2C kasi noon kasama AT transmission, in our case engine lang ginamit namin.
    Feb 2019
    #37
    okey guys what do you think about this car naman? nasan na kaya si Audacity Find My iPhone Origin Client for Windows and macOS[/url] aalala kong gusto magpakta ng pic ng pinagandang tamaraw e..
    okey maintenance, reliability, fuel efficiency, etc! at may diesel ba nito? ask ko lang :D
    kahit ilang years from now may makukuha kang parts nyan. tutoo yun na pag inayusan mo FX e maganda din talaga
    Jun 2018
    #38
    Quote Originally Posted by bosstl View Post
    sir, yung tamaraw FX as i know is one of the pioneer passenger AUV here in our country, so in most cases, it lacks the usual power amenities na meron ngayon sa mga current models ng AUV.basically yung FX kasi was designed to haul passengers. very crude yung design, somewhat an experimentation of incorporating the seating arrangement of an SUV to a smaller body of an AUV. pero it serves its purpose, kaya nag-click sa atin.
    in terms of maintenance, ang sakit sa ulo lang naman ng FX e yung makina. initially, nakasalpak sa kanya e 5k. this is a small engine for its body size. kaya malakas sa gas. kaya pinalitan nila ng 7K. lumakas nga sa torque, pero malakas pa rin sa gas. hahaha. about their diesel engines... one word. panget. bad rep ang 2C. kung papa-overhaul ka rin lang nito, better kung magpalit ka na lang ng makina (and as for my case, nagpalit ako ng 4AGE). another member also had his engine to 4AGE. si EssB.
    i think i have some pics of some mods i made sa FX namin. hmmm... try nyo po tingin dito... www.cardomain.com/id/bosstl
    kamusta na po tamaraw fx niyo? baguhan po ako dito and about 5months ago nakakuha nakong driver's license, I really like the tamaraw fx and yun ang papagamitin sakin ng parents almost feel like my own car hehe (sana naman) Gusto ko ma experience yung mag taga off roading so gusto ko rin malaman ano mga future upgrades pwedeng magawa sa tamaraw fx ko
    #39
    every sunday morning may nakikita ako pumaparada na fx sa village park namin. nagsisimba iyong owner i assume. medyo pinormahan at ang kinis!
    mukhang sunday car nung may-ari
    #40
    May nakita ako a few months ago na pristine Tamaraw FX, not sure kung restored or alaga lang talaga. Looking at it, 90s an 90s ang dating, complete with period correct OEM wheels.
the tamaraw fx!
