Once you put the shift lever to M or Manual mode it will stay in the middle of the + and -. If you are in a full stop and put it at M, nasa 1st na po yun gear. If you are running and put it to M, it will retain the current gear where you are in. Shift it to either + or - when you remove your hand on the shift lever it will go back in the middle of the +& - position.
