Results 1 to 20 of 57
    2014 Altis
    Posted via Tsikot Mobile App
    Dec 2007
    2014 Altis
    Once you put the shift lever to M or Manual mode it will stay in the middle of the + and -. If you are in a full stop and put it at M, nasa 1st na po yun gear. If you are running and put it to M, it will retain the current gear where you are in. Shift it to either + or - when you remove your hand on the shift lever it will go back in the middle of the +& - position.
    Quote Originally Posted by markygy View Post
    Thanks. So when I am going to pass through flood, I will do a full stop first then shift to M? After passing the flood, I can shift direct to D?
    What is the purpose of the + and - pala?
    I don't know if I am being paranoid pero parang iba na takbo ng auto ko I know that a civic and city easily passed through the flood in Buendia but what I am worried about e baka nagshift yung auto while I drove through the flood on D It's gutter to a little over gutter deep kasi may dip yung road.
    Same question as 3GEMS, what needs to be checked after driving a flooded road?
    Dec 2007
    Yes, better to make a full stop and think twice if you're going to proceed. You can directly shift to D from Manual mode (M) regardless of the car's speed.
    Like what was posted, to shift to a higher gear use + and to shift to a lower gear use -. Do not worry using this feature, if the ECU of the car detects that your speed is to low for the gear you are trying to shift to, it will simply not allow it to shift. On the other hand if the ECU detects that your gear is to high for the current speed you are in and you fail to down shift using the - the on board sensor will kick down the gear for you automatically.
    I suggest playing around with this feature you have on your car to get yourself more familiar with it. It's fun to have this kind of feature.
    Besides looking for any icon that just suddenly lights on the instrument panel. Pull over on a safe side on the road and check the ff: Raise the oil dip stick and see if you can find droplets of water on it or if the oil level is unusually very hiigh, it will be obvious since water and oil don't mix. Open the engine air filter box and pull out the air filter, check if it is wet. If you find water on those mentioned, then don't bother starting the engine, have your car towed to the nearest mechanic.
    More evident is the color of the engine oil. Kung Mukhang milo na, well yun na yun. Hehe
    Oil level is not accurate because umiikot oil sa makina.
    Oil and water do mix by imulsification.
    Water ingress to engine seldom happens not unless the entry is in your air intake, but at considerable amount of water ingested would result to an airlock.
    Checking breather tubes(axle, trans, transfer) would be more concerning as these vents usually are placed in confined spot. Damage due to water ingress on these parts would be almost hard to notice untill the day weird noises are heard, and by that time its too late.. These breathers are usually located just below headlight level.
    Basing water fording capability on air intake alone is risky. Most cars nowadays tho at hood level intake have resonators as low as the radiator and these resonetors are not totally sealed.. Pickups and most SUV's do get the advantage because of air intake inside fenders, plus there are lots of aftermarket snorkels to further raise the intake.
    Jan 2014
    You dont have to stop when changing to M fr. D
    + is to shift to higher gear and - to downshift
Survival Guide: Driving Through Floods 101
