Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    does the sentra lec model really uses timing chain instead of timing belt?
    Jun 2006
    Yes it uses a timing chain. I may be wrong but I belive all newer model Nissans use t-chains.
    With a chain, you dont have to worry about changing it. Its supposed to last the life of the car.
    Nissan at Suzuki lang ba ang gumagamit ng timing chain?
    Jun 2006
    Toyota Avanza ay naka chain. Ford Expedtion, E150, F150 also uses chain. Chevy Venture also equiped with chain. I'm sure may iba pa just cant remember kung anong models.
    Feb 2007
    I think gas engined Toyota Revo's use a timing chain also.
  6. #6
    mali ka, wala pa ko nakikitang local revo na timing chain--7k is still timing belt, 1kz, 1zz, 1kd, etc.. all passenger models ng toyota uses timing belt. nissan offers timing chain talaga, from ga16, qd32, td27, sr20, etc....
    and i dont believe na makina ng avanza ay timing chain.. its practicallty the same as what the vios/echo has.....and most top-end models nga ng toyota timing belt parin...even diesl engines...
    alam ko timing belt pa rin ang Avanza.
    Jun 2006
    basta sa akin kahit ano pa yan chain, belt or gear basta nasa timing sya ok yan.
  9. #9
    yup, this should not be a big issue..
    pero siyempre lesser maintenance ang chain, especially the gear then the belt...
    most new toyotas naman has an T-belt indicator on the dash..
    Jun 2006
    Napa research ako sa thread na to.
    I'm 100% sure that the Avanza uses a timing chain. I asked a Toyota sales rep about it before purchasing my unit. It was also confirmed by another Avanza owner in the Toyota Avanza thread. And to validate, I just checked my owners manual. No mention of checking, inspecting or replacing a timing belt in the maintenance section.
  11. #11
    sa hood-stickers???
    Jun 2006
    Quote Originally Posted by alwayz_yummy View Post
    sa hood-stickers???
    Just checked, no info kung chain or belt sa hood stickers.
  13. #13
    pareho lahos ng engine ang avanza sa vios, konti lang difference.. hmm matignan nga brochure kung meron..
    ung revo ko 7k makian. nasa 200k na tinakbo sir d pako nagpalit ng timing belt. ang sbi kasi saken ng mekaniko timing chain daw ito...
  15. #15
    2L, 3L nga timing belt, 5K din....
    basta toyota, expect na makina nila is timing belt...
    Aug 2003
    ang sabi sa kin ng toyota salesperson, basta VVT-i makina, timing chain na
    Research.... research......
    Timing chain nga ang Avanza
    uhm... ung 2000mdl namen na hiace 5L makina timing belt. may indicator sa dashboard kapag kailangan na palitan timing belt. nung 80k na tinakbo pinapalitan na namen kahit d pa umiilaw. double check ko ung revo namen. 7k makina nya
  19. #19
    oh well...
    Oct 2004
    *alwayz_yummy:
    The following Toyota engines on timing chain:
    K series
    R series
    ZZ series
    NZ series
    SZ series (3SZ-VE also K3-VE - both from Avanza)
    Marami pang iba (pero yan ang mga locally released)... marami pang ibang series....
timing belt or timing chain?
