Page 1 of 2 12 LastLast
Results 1 to 20 of 36
    The 4 four turbos are already in place including the pipes that supply them with fresh air and the pipes that leads to the intercoolers.
    Pipes from the intercoolers to the carb box is already done.
    The air Cleaner is positioned adjacent to the carb box to get fresh air from the hood scoop.
    Please visit the link to view the pictures:
    1. Air Cleaner with the 4 supply pipes to the turbos.
    http://www.flickr.com/photos/81856035*N00/473038690/
    2.The two turbos located in the passenger side of the engine.
    http://www.flickr.com/photos/81856035*N00/473038686/
    3 The two turbos located in the driver side of the engine.
    http://www.flickr.com/photos/81856035*N00/473038698/
    4.Long shot to show the intercoolers and aluminum radiator.
    http://www.flickr.com/photos/81856035*N00/473038664/
    5.Side view to show locatin of parts.
    http://www.flickr.com/photos/81856035*N00/473038676/
    6. The Corvette independent rear suspension already installed in the rear of the Eleanor.
    http://www.flickr.com/photos/81856035*N00/473038722/
    putek hayup!!! eto yung kelangan ata ng wheelie bars!!!
    Quote Originally Posted by ssaloon View Post
    nyahahah :bwahaha:
    Functional hood scoop of Eleanor.
    http://www.flickr.com/photos/81856035*N00/473154201/
    Air cleaner is evident inside the air scoop. This is a functional Ram Air scoop.
    http://www.flickr.com/photos/8185603...n/photostream/
    Eleanor besides my brother's 69 Mustang Fastback.
    See how the 69 FB is slang really low.
    nice!!! nakakabit na yung 4 na turbo! vroooom!!!!
    couple of questions lang sir turbo:
    1. Paano mo na co-control ang boost?
    2. Any changes sa engine internals prior to tubrocharging? im trying to think of the cheapest way to get extra HP for future upgrades
    3. Yan na ba yung pipes na gagamitin? Kelangan pa bang i-thermal wrap yan or coat?
    4. Magkano inabot? hehe
    5. Para sa akin ba yung blue na 69 sa tabi nyan?
    6. What are the pros and cons of turbo vs NOS, i remember kasi naka NOS yung kay gatchalian, why did you opt for turbo? Which is cheaper? Kamusta na pala yung kay gatchalian, post mo na sir
    1. Lalagyan ko ng blow-off valve sa air box, tapos lalagyan ko ng cable adjustment sa cockpit para pwede gawin variable ang boost pressure. Sinara ko na ang waste gate.
    2. First the stock compression ratio of my 460(7.6 liter) is 8.0. So that will be ok. Pero to be sure bibili din ako ng Forged pistons kasi lalagyan ko din ng NOS Fogger. Meron na akong 2.25/1.75 valves. Need a camshaft with long exhaust duration and low lift. Rods and crank are already heavy duty, kasi truck motor to.
    3. Thermal rap sa exhaust side. Makapal ang ginamit kong pipes. Paint na lang sa intake and pressure pipes.
    4. Mura lang, kasi mga surplus na turbo at intercooler lang ang ginamit ko. Wala naman kasi akong pera.
    5. Hehe. Sa kapatid ko yon. Lalagyan ko ng Cleveland heads yung 302 para maging Clevor/Boss. Hintay ko lang yung ibang parts.
    6. Turbo kelangan mo ng mas efficient na cooling system. Mas matagal gawin dahil sa pipes, plumbing for air and oil and water. pero efficient power adder.
    NOS, easy to instal, pero pag ubos na gas, wala ka nang back-up power.
    Hindi kay Wesley Gatchalian yong naka-blower, kay Jack Roxas yon. Yung kay Wesley, body lang ang ginawa ko.
    Nakagawa na kasi ako ng Supercharger kaya turbo naman. Gusto ko kasi yong iba, para personal talaga.
    Malapit nang tumakbo yung kay Jack Roxas, electrical na kami.
    Yung kay Gatchalian painting na, medyo na-delay, kasi candidate sa Valenzuela ngayon.
    Hope, I answered you.
    Sep 2005
    Hayuf!!! Ang ganda!!! Kailangan na yata ng parachute nyan to stop! ZZZZZooooooooooooooommmmmm!!!
    Sep 2006
    how much psi are you planning?
    carb or efi ba to?sorry no familiar with muscle car?
    Why do you need to put 4 turbos?
    sequantial ba or parallel ang design?
    For this engine, 7.6 liter, which to begin has tons of torque, I am gunning from 7-10 psi. Anything more will be unmanageable. Although, I am putting a variable pressure regulator in the cockpit.
    I am still using Holley Double Pumpers for simplicity and instant response.
    I am using four small turbos so that boost will be instantaneous even at low rpm. And very few has done a 4 turbo set-up. I want to be different.
    Parallel and design, easier to balance and no need of computer that will go wrong.
    Sep 2006
    Goodluck!!!!
    I never rely on luck.
    I have done it before on less rigid engines. Things will always go wrong, it was my job before I retire to make things go wrong less.
    But this is something new, so I will just cross my fingers.
    that thing will be f-ing sick. on that big an engine, i would think twins would be more than enough, but as you said, you want to be different...with 4 turbos, you'll certainly be top dog...unless your neighbor has a Veyron
    how are you planning to put all that power onto the ground?
    Rear end will be 315/35/17 rubbers I got from Ebay.
    The differential is Dana 44 with 4.11 gears from a C4 Vette. I hope that it will not break. I used heavy duty square bars for the torque arm of the differential.
    Stopping it will 4 disc on all side from a C4 Vette with hydroboost assist.
    I reckon another 6 months to finish the project because I am doing the roll cage and further reinforcing the body. Baka pumilipit.
    Last edited by turbo; April 27th, 2007 at 10:17 AM. Reason: dana 40 corrected to dana 44
    Quad-turbo V8. Interesting
    You plan to make this a drag racer or one of those 200mph long-range cruisers like I've seen in the Silver State classic?
    With the 4.11 gears sitting at the rear end now, it will be a good drag car. But I'd rather use it as a cruise so back to ebay for 3.0/3.25 gears.
    These are the wheels and tires I got from Ebay.
    They are Vredestein 275/40ZR17's AND 315/35ZR17 tires. The Vredestein tires are designed in Europe where high performance cars must handle the challenges of the high speed Autobahn. They are speed rated at "Y" for up to 186 MPH!
    http://www.flickr.com/photos/81856035*N00/474038862/
    The front wheels are 17" x 9" (+24mm with 5.95" backspacing) and for the rear 17" x 10.5" (+27mm with 6.9" backspacing). I opted for the all-Chrome wheels.
    Thanks for the clarification sir turbo
    So before turbocharging, kelangan pala muna heavy duty internals. What about supercharging? Which is cheaper? kuripot kasi ako kahit nangangarap lang
    Sorry Double posts.
    Yes you have to have heavy duty rods, pistons, even 4 bolt bearing caps.
    Yong Supercharger na ginamit ko kay Jack Roxas, $180 lang. Kasama na ang intercooler at mga pipes. Convert ko na lang sya ng side-mount, instead of top-mounted directly to the intake manifold. Tapos naglagay na lang ako ng 8 inch drive pulley at 3 inch blower-driven pulley. Gagawa lang airbox.
    Laki ng kamurahan kesa sa Paxton/Progear centrifugal blower. Naka Roots type ka pa.
    Wait ka, ang susunod ko sa 396 Hi-compression 68 camaro ko ay isang 6-71 Blower na 350. Makina lang ang gagawin ko. Wala pang donor car. Dapat yung CROSS RAM ang susunod ko, kaso nabili yung Z-28 Cross ram set-up ko. Hehehe.
    Hanep!
    sir, sa ebay mo pa rin ba binili yung variable pressure regulator mo?
    electronically controlled po ba yan?
Quad Turbo Eleanor
