Results 1 to 10 of 15
Threaded View
Tsikot Member Rank 3
- Dec 2002
- 551
March 12th, 2004 02:26 PM #7engine model : 4G15
type : SOHC 12 valve, gasoline
fuel system: variable venturi carburetor
displacement : 1,468cc
bore x stroke : 75.5 x 82.0
compression ratio : 9.0
max. output kw(ps)/rpm din net : 65(88)/6000
max. torque : nm(kg-m)/rpm din net : 120(12.2)/4000
top speed 180kph (M/T) - 170kph ( A/T)
brakes front : 13" ventilated disk
rear 7" leading and trailing drums
brake booster 9" master vac
hope this helps you : )
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
