Results 1 to 9 of 9
October 26th, 2006 02:53 PM #1
i've searched previous threads re. halogen bulb but medyo konti ang
comparo bet OSRAM silverstar and PHILIPS vision plus considering the
same wattage. i'm currently using my stock again after busting one of
my super white. can i hear some good characteristic bet the 2?
all weather (NARVA, OSRAM and PHILIPS) is also my second option.
TIA mga sirs.
October 26th, 2006 02:59 PM #2The H4 +50 bulbs from the big four reputable European bulb makers (Philips VisionPlus, Osram SilverStar, Narva RangePower+50, Tungsram Megalicht) are functionally identical. When we pick ten samples of each and put each one through photometric, optical comparator and life tests, there's a very narrow range of performance and life differences, and those differences are randomized among the four brands.
October 27th, 2006 07:35 AM #3
price wise, mas mahal ang all weather bulbs...
im using visionplus right now..ok naman, pero medyo mahina na visibility pag basa na yung road (especially on asphalt)
dati din i was using silvervision, same findings as above.
October 28th, 2006 12:11 AM #4
silvervision? diba pang signal lights lang yun. silvervision bulbs are amber bulbs coated silver which are used for clear signal lights.
mas mahina visibility ng superwhites than all weather bulbs on ashphalt
October 28th, 2006 12:48 AM #5
i've experienced fuses blowing with other super white bulbs, especially those saying 55W input then a higher output. nasolve problem ko when i switched to philips. sana nga ng philips na lang agad ako in the first place para di dumoble gastos ko. i got the diamond vision, ganda ng color. wa kwenta nga lang pag umuulan, wahahaha
- Nov 2006
- 85
November 2nd, 2006 12:34 PM #6I have Silverstars on my Lexus, both headlight and fogs and they work great.
Tried and true.
- May 2005
- 47
November 2nd, 2006 03:55 PM #7Currently using Silverstars on my headlight. They are 1 year and 3 months old and still working. Big improvement over the stock Philips bulbs on light intensity. I haven't used the Philips Vision Plus though so no comparison between the two.
November 2nd, 2006 04:52 PM #8
OSRAM silverstar, bit whitish than stock but not as damn super whites,
stock wattage and better light throw, good for city driving
November 2nd, 2006 05:26 PM #9
I like this thread, because I'm also in the option of replacing my stock headlights, not busted but feel like the beam has degraded. About the headlights, I mean the bulb perse degrades its illumination overtime? (Don't worry about the lens and reflector, they are in good and excellent clear condition).
Right now I'm leaning towards using Philips Vision Plus, 'yon kasi madalas ko nakikita and it costs PHP850. Eto 'yong may parang stripe na blue sa tip niya.
