Results 11 to 20 of 32
February 5th, 2008 08:26 AM #11
It should not only be the engine and battery that you should be concerned about, other parts need lubrication also. It's better to drive the car around the block one a week if possible.
- Jun 2004
- 207
February 6th, 2008 02:47 AM #12
February 6th, 2008 01:58 PM #13
Why not disconnect the negative from the battery terminal? I do this when I fly to manila for a week para di madiskarga ang battery.
February 6th, 2008 02:26 PM #14
sa actual experience ko, 3 months na hindi nagalaw ( as in para siyang naka impound lang
) yung CRDI na sasakyan ko, wala namang naging problema nung gamitin ko ulit.
- Jun 2004
- 207
February 7th, 2008 06:38 AM #15Bale alin ang "lesser evil", disconnect the battery o paandarin at idle lang (for 5 to 10 mins) weekly/bi-weekly?
February 7th, 2008 07:01 PM #16
Hay...
We had bad experiences when it comes to NOT USING THE CAR FOR A LONG PERIOD OF TIME.
1) Lancer MX 2000
- Was not used for 2 weeks, the speedometer got busted. The gauge hands don't work na. When you start the engine, walang gumagalaw sa mga gauges, parang patay na yun makina. Needed to change the speedometer, 10k damage. Gauges did not work, but engine will start pa rin naman.
2) Audi A4 2000 A/T
- Worse. Was not used for 3 weeks, the immobilizer got busted. Car starts, car wont. Car starts again. Car wont. You go out of your home, park at the mall, go back, BAM! Car won't start na. Call the towing (because hindi pde i-series or whatever). Damage 2k blah blah... Change the immobilizer (with the speedometer, kasama kasi yun eh) BAM! 48k! (or more ata yun, hindi ko na inaalala, sakit sa bulsa eh) Down the drain!
All prayers, no more #3.
What we do, warm the engine.
Payo ko sa yo. Warm your engine. Don't leave it there alone. Lalo na Diesel ata yan.
Just sharing.
Tsikot Member Rank 4
- Jan 2007
- 2,326
February 7th, 2008 07:55 PM #17You're really after the shape nung gulong -- hindi (lang) po ang pagsingaw. Kung hindi kasi titigasan ng konti, yung steel belts niya might remain in the oblong position.
I'd suggest normal air lang na dagdagan ng psi depende sa recommendation ng gulong (imbes na ng kotse) and fix any leaks from holes and valves.
February 8th, 2008 12:31 PM #18
This is the best one.
The Mazda3's battery went flat because of the integrated immobilizer. A lot of new security systems and ECUs will trickle-drain the battery over time... you can disconnect the battery, but you should also start the car every now and then to charge up the battery.
And you should drive it around... let it get up to operating temperature and let the lubricants circulate fully.
But if you're going to be away and can't drive it, and no one will be there to do it for you, you might want to invest in jack-stands to take the load off the tires, or over-inflate them for the storage period.
- Jun 2004
- 207
February 15th, 2008 08:34 AM #19Ok, I will follow your advise and try to get someone to drive the car around the block at least once a week. In addition, the tires will be filled with nitrogen to greatly minimize pressure loss.
After the 5 months has elapsed, would it be necessary for an immediate oil change (regardless of the mileage reading) before putting the car back into regular use?
- Jul 2006
- 41
February 16th, 2008 11:47 AM #20
From what I have seen, some premium/performance makes, like BMW, suggest weights(sand bags) on...
Wheel Alignment
