Quote Originally Posted by k0t'si View Post
hi every one, newbie po ako...gurl...ownr of isuzu xuv 2003 model, na broke kc ung pipe nung car need palitan ng FLEXIBLE pipe... ano ba ang mas ok ipakabit bigger pipe or meduim size lang... mdyo mahal kc ung bigger pipe it cost almost P3k...help namn... wala kc ako alm sa ganito e...thanks...hope some body hav a heart to give me good suggestion...
hi kot'si,
if you're talking about the radiator upper hose (the black rubber pipe connecting the engine to the radiator)...i suggest you do the ff:
if the break is near the end or the clamp (metal ring that holds the hose), have it cut nicely and re-attach using the same clamp.if it's a bit short, you can interchange with the lower radiator hose, as long as you duct tape and seal tight the break in the hose as a temporary solution. i would still use the same size of hose or pipe and the same material as much as possible..try scouting for a much cheaper hose here in masangkay and soler (binondo)...ignore this reply if you're refering to the tail pipehope this helps.
