Results 1 to 7 of 7
    hi every one, newbie po ako...gurl...ownr of isuzu xuv 2003 model, na broke kc ung pipe nung car need palitan ng FLEXIBLE pipe... ano ba ang mas ok ipakabit bigger pipe or meduim size lang... mdyo mahal kc ung bigger pipe it cost almost P3k...help namn... wala kc ako alm sa ganito e...thanks...hope some body hav a heart to give me good suggestion...
    Quote Originally Posted by k0t'si View Post
    hi kot'si,
    if you're talking about the radiator upper hose (the black rubber pipe connecting the engine to the radiator)...i suggest you do the ff:
    if the break is near the end or the clamp (metal ring that holds the hose), have it cut nicely and re-attach using the same clamp.if it's a bit short, you can interchange with the lower radiator hose, as long as you duct tape and seal tight the break in the hose as a temporary solution. i would still use the same size of hose or pipe and the same material as much as possible..try scouting for a much cheaper hose here in masangkay and soler (binondo)...ignore this reply if you're refering to the tail pipehope this helps.
    hi, magdencio.thank you...yun palang nasira ay yung sa tambutso... for sure makakatulong yang info na bigay mo in the future... medyo may mga naeencounter pa din akong ibang problem, like ung hindi nya pagstart minsan...mga nagkakalugan sa door.hay, hirap pala nung walang alam sa sasakyan....thanks sa help ha, sana pagmay question ako andyan ka ulet...
    Jun 2006
    Ang mahal naman ng flexible pipe na yun para sa tambutso. Goma lang yun e. Try mo humanap sa banawe (or maghanap ka ng mauutusan). Lakarin yung buong banawe (maliit lang yun). tapos hanap ng surplus. Siguro mga 500-800 lang yan.
    Paano pong ayaw mag-start?
    hi,
    Start ako sa morning ok... pag off engine, minsan bigla nalang ayaw magstart as in magintay ka muna siguro almost an hour bgo ulet magstart or wait another day start na ulet sya? pina check ko sabi sa remote daw...hindi ko alam kung asan ang remote nun..A/T sya eh..
    P300-P400 lang yan flexible hose na surplus
nEed Help...
