Quote Originally Posted by HBOY
on all matics P,D,R,N are normal parts.. it differs on the forward gears...
if teh number has a D(X) beside it it means it shifts to all the gears up to the number indicated. (D4 - all four gears, D3 - up to 3rd gear only, D2 - 1st and 2nd gear)
if the markings only say "2" like in most honda cars, it means it is locked in 2nd gear.. no shifting whatsoever... this is appropriate for standing starts for roads that are slippery and you dont want your car slipping.
1, L - are 1st gear settings for heavy inclines.
S - Sometimes considered as sports gear (in MBs), Slope Gear in Jap cars
- for MBs this is teh same as teh D3
- for jap cars.. ewan.. eheh. i think low gearing to eh...
hmm.. what else? .. OD button? Overdrive and ibig sabihin.. usually with OD of you shift only up to the third gear (if its a 4matic car). With OD on, the car has teh extra fourth gear to shift in.. less fuel consumption, less stress for the engine. Used mostly on travels wherein gear hunting happens.. not enough speed to carry it in 4th gear, but too fast for 3rd... kung baga alanganin.. instead of your tranny shifting back and forth, might as well put it in OD off.
on stops (short stops) keep it in D or Drive. On long traffic gnarling stops.. put it in neutral, minimal but still savings on gas plus less stress on your tranny, engine and brake system.
Never engage to P when on an incline without making sure first that your car wont be rolling anymore by engaging teh Parking brakes. Engage parking brakes first. Release brake pedal. When the car is in complete static position only then you should engage in P. The P has a pin mechanism (very small easily broken by a suddent movement on the car) that locks the gears.
Hmmm. ano pa ba?... Dont disengage to Neutral when travelling (one delikado) because you loose the hydraulic pressure in the tranny when rolling in neutral. Something i cant explain completely.. basta something with the ATF fluid not going around the tranny. That's why A/Ts are not meant to be towed or push started.
one last.. dont shift from D straight to R or vice versa while the car is still in motion the opposite way... sira ang mga ngipin ng gears mo nyan.....
*baka may mali po akong nasabi... i'm open for corrections.. these are all from either experience, internet and talking to some mechanics. Baka may mali lang ako sa pagkakaintindi habang nakikinig ako o nagbabasa.. eheheh
Dude that was very informative and I really appreciate it. I have another question:
When I drive I usually use only D, P, N and OD. I don't usually use L and 2. Masama ba sa tranny when you go up inclines na naka D lang? Pag going down an incline what do I use to relieve the pressure on the brakes?
