Results 1 to 10 of 17
May 22nd, 2007 11:08 PM #1
Gusto Ko I Lowered Ung Auto Ko. I Drive A 97 Honda Civic.. My Friend Said Na Bili Na Lng Daw Ako Ng Surplus Na Rear Coils Springs Tapos Lagay Ko Sa Harap Saka Putulan.. Meron Na Ba Gumawa Sa Inyo Nito? Ala Kc Ko Budget Eh.. Mag Fit Ba Un? Need Help Mga Bossing ^^ Tnx
Tsikot Member Rank 4
- Jun 2006
- 1,046
May 23rd, 2007 01:45 AM #3
May 23rd, 2007 02:01 AM #4
Try second hand lowering springs.
Read up on other threads about lowering. The common theme is: DO NOT CUT.
May 23rd, 2007 02:03 AM #5
Just noticed the you want to put a rear spring in the front and cut it. That's even going to be worst because the front is heavier than the rear and if you cut it you'll aggrevate the problem. Here's a suggestion whatever ideas your friend has about cars don't listen to him unless you don't like your car much.
May 23rd, 2007 02:20 AM #6
yes, just settle with second hand springs. mortal sin ung pinuputol!!!
karamihan sa naglo-lower ay nagiinstall ng shorter springs. ito ung pinakamadaling ma-achieve ung lowering.
An alternative, is to relocate the hubs and spindles upwards. This is ideal since it lowers the car without changing any of the suspension geometry.
May 23rd, 2007 11:04 AM #7
simple, if you dont have the budget right now, dont push through with your plans of lowering your ride. just save up for bnew/2nd hand lowering springs. do it right the first time, it'll save you a lot of headaches and $$$.
May 23rd, 2007 03:46 PM #8
Secondhand lowering springs don't cost that much, and they don't lose that much stiffness over time (compared to stock springs).
Does your friend know much about Civics? The rear coils of the Civic have much lower spring rates than the front... not to mention the fact that they're actually longer than the front springs and they won't fit the stock front mounts.
Do it right. Buy lowering springs and don't cut the stock ones. You could possibly cut the stock ones if this were an SiR (SiR springs are pretty stiff, and don't bottom out badly if you cut one coil off... still doesn't ride as securely when you do this, though.), but not for a regular Civic.
May 23rd, 2007 06:05 PM #9
Also please type properly. I didn't even bother to read your thread because it was hard to read. You'll get more replies that way.
- Jul 2005
- 119
May 23rd, 2007 07:31 PM #10
Production of the next gen Kicks confirmed .......
2025 Nissan Kicks
