Results 1 to 17 of 17
    May 2007
    Gusto Ko I Lowered Ung Auto Ko. I Drive A 97 Honda Civic.. My Friend Said Na Bili Na Lng Daw Ako Ng Surplus Na Rear Coils Springs Tapos Lagay Ko Sa Harap Saka Putulan.. Meron Na Ba Gumawa Sa Inyo Nito? Ala Kc Ko Budget Eh.. Mag Fit Ba Un? Need Help Mga Bossing ^^ Tnx
    Quote Originally Posted by beerbelly View Post
    NEVER CUT SPRINGS. That's what everybody here will tell you, if you want a lower ride get lowering springs and do it correctly.
    Edit: BTW learn to type correctly your post is hard to read the way you typed it.
    Jun 2006
    sige putulan mo tapos balik ka dito sabihin mo sa amin kung ano ang nangyari. sabi nga nila, "learn from your mistakes."
    Jan 2004
    Try second hand lowering springs.
    Read up on other threads about lowering. The common theme is: DO NOT CUT.
    Just noticed the you want to put a rear spring in the front and cut it. That's even going to be worst because the front is heavier than the rear and if you cut it you'll aggrevate the problem. Here's a suggestion whatever ideas your friend has about cars don't listen to him unless you don't like your car much.
    yes, just settle with second hand springs. mortal sin ung pinuputol!!!
    karamihan sa naglo-lower ay nagiinstall ng shorter springs. ito ung pinakamadaling ma-achieve ung lowering.
    An alternative, is to relocate the hubs and spindles upwards. This is ideal since it lowers the car without changing any of the suspension geometry.
    simple, if you dont have the budget right now, dont push through with your plans of lowering your ride. just save up for bnew/2nd hand lowering springs. do it right the first time, it'll save you a lot of headaches and $$$.
    Aug 2004
    Secondhand lowering springs don't cost that much, and they don't lose that much stiffness over time (compared to stock springs).
    Does your friend know much about Civics? The rear coils of the Civic have much lower spring rates than the front... not to mention the fact that they're actually longer than the front springs and they won't fit the stock front mounts.
    Do it right. Buy lowering springs and don't cut the stock ones. You could possibly cut the stock ones if this were an SiR (SiR springs are pretty stiff, and don't bottom out badly if you cut one coil off... still doesn't ride as securely when you do this, though.), but not for a regular Civic.
    Jul 2006
    Also please type properly. I didn't even bother to read your thread because it was hard to read. You'll get more replies that way.
    Jul 2005
    kung wala kang budget , antayin mo nalang magkaroon ng budget then bili ka b- new
    May 2007
    ok tnx guys.. how much ba 2nd hand lowering springs? and Bnew?
    Aug 2004
    Brandnew? Maybe 10-15k, if you're lucky. And since there are many brands and types available for the Civic, it's easy to get lucky.
    Maybe 4k-8k secondhand, depending on how expensive the springs were when new and how used they are.
    Nov 2006
    how much of a drop are you looking for? are you looking to for stiffer spring rates as well or do you wanna keep the ride comfy? I might be able to hook you up... do you have a coupe or hatch? hit up my yahoo messenger: driftoholic1 or email me at driftoholic1*gmail.com
    Mar 2007
    i've also been thinking a lot about lowering my ride.
    can i just install lowering springs without replacing my shocks?
    anybody got a good idea what brand/type of lowering spring would be best for a sentra b13? a 1.25 inch drop would do... i'd also want to keep my ride comfortable - my in-laws usually ride with me... hehe
    i'm planning to get 16" rims and 45/205 tires. kasya kaya yun - i mean, sana di sumayad sa fender when cornering.
    thanks guys!
    Nov 2006
    Quote Originally Posted by kyoots View Post
    thanks guys!
    ...I would recommend Tanabe NF210: http://tanabe-usa.com/springs/nf210.asp or Tein H Tech: http://www.tein.com/htech.html I'm not sure about the application for your car tho'
    you can get away with using your stock shocks but that all depends on your current shock's condition.
    hth
    May 2007
    Quote Originally Posted by ssaloon View Post
    Nice quote ssaloon! "Do it right the first time" its true. Its a quality job done.
    May 2007
    thanks guys!
    205/45/16 is okey for your car but you need to know your wheel (rim)offset. Your Sentra offset is I believe 40 to 42. Just make sure doesnt rub your fender.
    Also, 1.25 is ideal drop but, maybe just maybe youll going to need a camber kit. Ask your installer or tech when they do allignment on your car after all the installation ....if you need one.
Lowering
