Results 1 to 13 of 13
    What is/are the best ways to increase acceleration without voiding warranty? Baka kasi makabili ako ng first AT ko eh alam ko isa ito sa weaknesses ng AT lalo kung walang sportshift. Hope you can give your 2 cents worth.
    Oct 2003
    -step harder on the gas peddle.
    -remove excess weight.
    you cant have it all....
    Quote Originally Posted by pup2 View Post
    You can shift the a/t tranny manually between the gears and run the engine up to the red line between shifts. Downside of this is the increased transmission wear & tear if you do this on a regular basis.
    Jul 2006
    And only do it if it's still within the break-in period. Otherwise you may have to take it back for repairs. Just read the manual and know the individual gears' speed limits so you won't over rev the engine.
    Aug 2004
    Intake, Headers and Exhaust, technically shouldn't void your warranty (as per US court ruling), but some dealerships take any excuse to deny it. Exhaust work from the catalytic converter back shouldn't void anything but your exhaust warranty.
    Lighter mags and tires will void your mag warranty. They'll try to claim it against your suspension warranty, but if you can show that the combined weight is less than stock and there are no fitment issues, you can take them to court over it. Lighter mags will improve low-speed pickup, and every 3-5 pounds of weight reduction from the mags will equal about 1 hp more. Not much, but it helps.
    Otherwise, there's not much else you can do. You can lighten the vehicle further by taking out the spare, but since a full-sized spare only weighs about forty pounds, that's not much difference.
    Salamat sa mga response guys! Just wondering -- eh kung air filter kaya?
    Aug 2004
    Sa AT? You'll notice better throttle response (as long as it's a good filter), but the power increase will be small.
    Aug 2003
    speedlab's CAI for the mazda3 1.6L adds 12hp at 4500rpm!!
    and dyno-tested at that.
    best 11,000 you ever spent. am thinking about it but afraid of the warranty issues. the mazda3 1.6L sure needs that 12hp..
    IMO - a muffler is the probably the SAFEST and only upgrade that you can do without causing your service advisor to raise his/her eyebrow when a warranty job is needed.
    You can also put in a drop-in free-flow air-filter that you can replace with the stock paper filter everytime you drop by for the PMS.
    Quote Originally Posted by mazdamazda View Post
    Malaki-laki ba iiimprove ng acceleration nun M2?
    May 2007
    drop-in freeflow air filter po. para pwede nyo din po ibalik yung stock filter element before kayo magclaim ng warranty or magpaservice sa casa.
    Not really, the gains are minimal but if you have been driving the car long enough you'll notice the difference.
    be careful in choosing an aftermarket muffler, you could lose some torque if you get one that's too big. chambered muffs are best for AT's imo.
Increasing acceleration with warranty?
