Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Dec 2015
    ** DCT not included
    Hi
    What's the proper to slowly inch forward in traffic using AT / CVT?
    Should we alternate between D and N or just use the brake?
    Thanks
    Quote Originally Posted by urbanmetal View Post
    ** DCT not included
    Hi
    Thanks
    keep it in D and use the brake pedal.
    you can also shift from D to N to D, but only if the waiting times are long-er. but even then, personally, i find this irritating sometimes.
    bottomline, do whatever feels less irritating to you.
    I drive a 6sp torque converter and at almost 240,000km it works great. I use "D" and brakes alone on slow or fast and even at full stop traffic.
    tip: get your right hand off of the transmission knob or your phone
    pag panay ang shift mo from D to N to D mapupudpod yung planetary gear friction band. so the best practice is to keep it in D and just use the brakes.
    Oct 2017
    Thanks for the tip...i have been playing with the gears D-N-D for a long time during long traffic waits... i have a feeling there will be wear a tear somewhere ...thanks again
    Sent from my SM-G950F using Tsikot Forums mobile app
    Sep 2006
    Oh no, I shift to N on 60sec red lights. Should I stay in D?
    Dec 2015
    5 Things You Should Never Do In An Automatic Transmission Vehicle - YouTube
    Found this video, which says the same thing.
    Thanks guys.
    Yup,- kung ayaw tapakan ang preno,- hilahin ang handbrake....
    Thanks guys.
    he must have said "wear" on the planetary gear friction band at least 10 times. eto na lang isipin nyo, walang magaling magoverhaul ng automatic tranny sa pinas. pag surplus hindi mo alam kung ang binili mo e ayos at tatagal, pag brand new naman ay sobrang mahal.
    isama na lang lagi ang syota/asawa/kabit sa kotse at humawak sa legs nyang maputi para hindi kung saan-saan o ano-ano ang kinakalikot ng kanang kamay nyo. kung single ka mangulangot ka na lang maluwag pa paghinga mo.
    pag bading, aba isama ang fafa at ikambyo ng ikambyo!
    Nag eenjoy lang ako panoorin videos ni Engineering Explained first few minutes. Nabobore na ako kapag tumatagal. [emoji23]
    sarap pampatulog 😅😅😅
    Mar 2004
    He explains too much ... like an engineer ...
    sa situation dito pinas....nakakangawit naman sa paa yung laging nakaapak sa brake.....
    so pinakamaganda na yung iangat handbrake....
    ako pag matagal-tagal stoplight inuneutral ko talaga.....
    importante kung sa comfortable katawan ko....
    nakakangawit talaga matic....
    Sep 2006
    Haha. I see what you did there.
    May 2009
    I say both have advantage and disadvantages. Its true bibilis friction band wear but not shifting to N will also hasten wear on your brakes. Which one is cheaper to maintain?
    Quote Originally Posted by granro01 View Post
    cheaper to repair ang brakes palit brake pads ka lang.
    Mar 2004
    Brakes are definitely cheaper to access and repair ... don't think doing so will wear out the brakes that much ... after all you are just holding the vehicle in stop position ...
    Sep 2006
    I think I need to change my driving style dahil dito
    I'll just engage my handbrake then.
    Sent from my SM-T705 using Tsikot Forums mobile app
Proper way to slow crawl in traffic using conventional automatic and CVT transmission
