Pag nahihilo kana sa sobrang tagtag when driving your car then it is too low.
never had any problems with mine.. ang auto ko dropped ng 3 inches in the back and front i never had any problems with handling, actually it handles better cause its low to the ground and i have 19 inch rims 245-35 kumho ventus.. it handles like an f-1 racer kasi ang baba talaga... but walan g pwedeng sumakay sa likod............sasayad ako pag me dip yung kalsada.. yung lang ang downside ko.....and it also depends on what kind of suspension you have in your car...
it depends too if your racing car that's too heavy............and packing a lot of system in his car.. but most of the time its on the driver too.... if he's too careful to shift then he can lose but if he's a gunslinger and doesn't really care well that's another story..........
^the guy lives in the philippines. much rougher roads, more road hazards (like the aforementioned super-tall speed bumps)...it's very different from the flat, smooth, well-maintained highways of Houston.
also a slammed (3+ inches lowering) car on 19's actually handles/performs worse...although it probably feels better because of the stiffer rating/valving of the springs and shocks.
also, a word on hydraulics - these things will completely ruin the frame of your car in time. the guys in the show cars don't care, but i guarantee your daily driven, primary car will handle/ride terribly and not last as long as you want it to if you install hydraulics.
The car is lowered properly using a kit that includes lowering springs and shocks so handling should be improved. I'm wondering if ground clearance will be an issue since the chin spoiler has around 6.5" of clearance. I realize this isn't really "slammed" but I'm also wondering about the "sayad" likelihood. The car is only about to see the road as it is still in the shop....just wondering aloud.....
meroon kaming 1981 toyota corona, kapag inupuan, nagiging lowered. salpok tuloy lagi sa humps. may remedy ba rito other than lift?
lowered ride height does not always lead to a harsh ride... some springs offer a lower stance without compromising the comfort level of the stock suspension. It all depends on the spring rate.
again, a properly lowered suspension would be able to maintain the stock compression rate and spring rate. Progressive coil lowering springs are capable of maintaining a smooth ride and the amount of compression if paired with the right damper/shock.
6.5" is okay... but you might still have to zigzag over some humps.
Heck, yung stock Jazz 1.5 sumasayad sa mga ibang humps... grrrr....
In some sanctioned racing events, the minimum ground clearance deems that no part of the vehicle may touch the ground when a tire is fully deflated.
Some rules call that no part of the body work may touch the ground when a tire is fully deflated and the suspension is fully compressed.
These regulations are in the interest of safety, not practicality.![]()
its depends, if you want pogi points to your ride make it lower, pero if you want comfort stock suspension..for me when i was stil single lahat ng auto namin linowerd ko..even our nissan vanette..way back 1994..pero if you have your own car at wala naman sumasakay na family pang pasok lang sa skul at pang chicks ok na ok ang mag lowered.. yun Pick up ko since 1998 until now eh naka hydraulics pa..bihira ko lang siya gamitin kasi meron naman akong ibang auto pang kalye..nga pala sa mga gustong manood ng mini carshow mamya sa eastwood libis nov.4,07 2pm onwards ,...nandun mga cars namin naka display...nandun din yun pickup ko..siguro linalabas ko lang ito 5times sa isang taon....hehehe kakatamad kasing linisin tuwing gagamitin...
ito pics
just consider the road!
sising alipin ako when i didn't put into consideration yun mga humps na dadaanan ko through our village before reaching our home. i was so attracted nung makita ko yun kotse na already low profiled kaya binili ko na. now, i hurdle at least 20 humps everyday before i reach our house(not to mention leaving for work). it even gets worse pag fully loaded na yun auto...you should really make it slow and almost parallel to the humps.
lalo na pag yun mother in law ko ang sakay ko...bagsak talaga!![]()
now the only "low" i know is:
4-LOW, 1st/LOW gear..
hehehe--sorry for the OT...
matter of looks and practicality yan--but be sure be safe, wag putol-springs....
