Results 11 to 20 of 79
March 19th, 2004 03:00 AM #11
Yung Bosch horns ko din noon.. nabasa lang nung nagpaunderwash ako ayun nangongo na tunog
March 19th, 2004 04:00 AM #12
un sa caravelle namin.. isang araw pa lang.. lintek na hella un.. sayang pera...
- Jan 1970
- 28
March 20th, 2004 02:47 AM #13I've been looking around and specs-wise, the Hella Supertones win.
Hella Supertones: 118db * 6'
Stebel Nautilus: 115db * 6'
As for the Fiamms, ang nakikita ko lang is some models are rated *130db but walang nakalagay na distance.
Sa Supertones, they have the additional advantage/disadvantage of being semi-directional.
Sa durability, case to case basis talaga. Masyadong varied yung mga experiences ng iba sa Fiamms, Hella and Stebel.
*GlennSter and odell
Anong model ng Hella yung nasira agad sa experience niyo? My old/stock horns were Hella's kase and they where mounted sa front grill. Recently lang nasira kahit na laging exposed sa elements.
March 21st, 2004 10:16 PM #14i have bad experiences with HELLAS.madaling masira eh..taposs pag nabasa..iba na agad ang tunog pag pinatuyo...fiamms..minsan nabasa na...buo parin ang tunog.
For me the best pa rin ang Bosch Supertones...:D
March 21st, 2004 10:49 PM #15
comparing the snail type horns mas malakas pa rin Yung stebel magnum. Ang katumbas nung Bosch supertones and FIAMM snail type yung Stebel TM 80. Stebel Magnum mas malaki compared to the other snail type horns
- Feb 2004
- 136
March 22nd, 2004 12:04 PM #17sirs, ano ba ang mga dapat bantayan kapag nagbago ng horn?
for example, installing a stebel nautilus... additional relay lang ba ang kailangan?
March 22nd, 2004 01:59 PM #18
Yung Stebel Nautilus hindi kasya sa stock horn location ng Pajero.
Mine is on the passenger side fender near the firewall (where it is safe from floods).
March 22nd, 2004 02:25 PM #19
Aftermarket horns draw more current from your stock horns. Additional relays will help produce its sound more efficiently. Airhorns such as Nautilus Stebel should be pointed down so as not to trap water in it.
March 22nd, 2004 06:55 PM #20
basta wag kayo kuha ng Bosch...2 beses na ako nagpalit, nabasa lang ng konti sira na.
I think we can agree to disagree on this. But I'm going to nitpick the point about deionized...
Coolant...
