Results 1 to 13 of 13
    got a 93 itlog lancer glxi
    its situation now is sbra na lowered dahil sa lowering sprngs then pinutulan pa ng knti..
    tapos mdme siyang squeaks under and i think sa suspension..
    i wud want to lifht it to stock sana..
    pero pangit na tignan.. kasi naka USDM na bumpers.. un extended.. tapos 16 inch na mags. kaya prng ang taas ng labas...
    dko alam ang gagawin ko.. gusto ko sana ganun parin porma pero mawawala un sqeaks.. posible ba?>
    o may other suggestions kayo?
    chong...compromised talaga yan pag lowered...
    bata ka pa kasi..kaya gusto mo porma talaga...
    pero habang tumatagal at tumatanda...maiisip mo na mas ok parin ang stock height...or lowered pero konti lang like my exalta.ung hindi maaapektuhan ang suspension mo.
    MAMILI KA.ikaw lang makakasagot niyang tanong mo...
    kasi baka ibenta din sometime before the year ends..
    pag ibalik ko ng stock lahat parang nakakahinayang na ayaw ko na dalhin.. :mrgreen:
    pero mas gusto ko na gamitin ride ng dad ko because of stock height matic pa..
    anu ba ginawa mo sa suspension glenn?
    maSUV nadin ako sa summer.. pero mtgal pa naman so gagamitin ko toh for haf a year.. d kasi ako makadecyd.. bago bago e..
    Cut pala springs mo, most likely wal na or sira na rubber dampers nyan at kumakayod na sa shock housing. try to check and install this. These are the moulded rubber seats between the shoch mounting and spring. there will be 2 in each spring one at the bottom and one at the top. Check this out since you cut your springs the spring ends will not be closed or leveled with thge shock housing so you will have an uneven contact and this is the squeecking sound that you hear.
    replace the springs
    put back the stock springs and replace the shocks to just lower it mildly (1" should suffice).
    if ever the springs were replaced / compressed / cut without changing your shocks to performance versions, it'll give out very soon.
    mazdamazda,
    how wud it lower 1 inch?
    i got h&r springs...
    1.5 inches ang drop.....
    ahh.. un softness ng ride?.. parang stock lang ba?.
    using the stock shocks?..
    teka.. diba ur gonna sell it na ult?..
    odell,
    bili ka na ng SUV..ano ba balak mo bilhin..?
    benta mo na yang lancer mo!
    benta n nga.. pero dko lam kng wen..
    next yr pa pag SUV..
    after my grad.. gamitin ko car ng pops ko for the meanwhile :mrgreen:
    balik mo na nga lang sa stock na springs...kung wala na yung stock springs, dami dyan sa surplus(mga 100 isa) para sa ride mo(ibebenta mo na rin naman eh)...imho
    ayus.. tnx :mrgreen:
help. opinions needed
