Cut pala springs mo, most likely wal na or sira na rubber dampers nyan at kumakayod na sa shock housing. try to check and install this. These are the moulded rubber seats between the shoch mounting and spring. there will be 2 in each spring one at the bottom and one at the top. Check this out since you cut your springs the spring ends will not be closed or leveled with thge shock housing so you will have an uneven contact and this is the squeecking sound that you hear.
