Results 1 to 7 of 7
- May 2007
- 133
March 22nd, 2009 05:51 PM #1gudpm mga papi, ask ko lang po kung ano kaya ang possible na problem, may grasa na tumatagas sa likod ng gulong ko, nakita ko lang kahapon ng inangat ung oto ko dahil nagpa change oil ako, sabi ng nag change oil e posible daw na na-worn-out na ung parang goma sa likod ng gulong, meron daw bearing sa likod nun, ano po kaya ang possible na problem? sa mga expert po sa gulong? bale yung likod ng gulong ko e may mga kumalat na grasa,
my ride is corolla 95 big body
thnx Godbless!
March 22nd, 2009 06:20 PM #2
baka sira rubber boot ng CV joint. pagawa mo agad yan. mahal masiraan ng CV Joint.
- May 2007
- 133
March 22nd, 2009 07:49 PM #3thanks sir, mga magkano po ba ung rubber?
ano po ba ang purpose ng CV joint? medyo konti po kc ang exposure ko sa pang-ilalim... thanks in advance!
March 22nd, 2009 08:37 PM #4
CV (constant velocity) joint is connected between your drive train and axle (tires). It transfer power from the engine/transmission to the tires. Flexible siya to follow the up and down and left and right movement of the tires.
- May 2007
- 133
March 27th, 2009 11:37 AM #5thanks sir, yung rubber boot nga ang problem,
pnalitan ko na cya and ok na ngyon
thanks ulit!
- 199
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
