Results 31 to 40 of 68
February 23rd, 2011 12:33 AM #31
Ito po pwede nag sleeper car.
Mitsu Triton 3.2 diesel AT stock engine and stock turbo 218Hp and 559 lbs of torque.
22 psi boost at 2,800rpm.
That is with only one chip but now it runs around 250Hp and 600lbs of torque added another chip for the injectors. That is only estimate kasi hindi po pa ulit na papa dyno with the 2 chips. But i did beat around and play around with an SIR and Evo3 in the highway kala kasi nila dahil mataas at deisel walang power hehehehehehehehehe.
- Jan 2011
- 100
February 23rd, 2011 03:31 AM #32
February 23rd, 2011 04:18 PM #33
February 23rd, 2011 04:20 PM #34
February 23rd, 2011 04:29 PM #36
parang hindi, iba plate design eh. tsaka mukhang hindi sleeper yan, ricey kasi dami stickers oh.
February 23rd, 2011 06:30 PM #38
*sir mikomac and sir ghosthunter yes thailand po ako and that is the starda diyan sa atin..................
*Sir Ry_tower proud ricey po ako thous stickers are my club sticker hehehehehehehe
Im a ricey with enough engine power .....................
Pwede na po bang sleeper car ito?
I can turn off my chips to run on stock mod and if needed i can flick a switch to run in modified mod also my exhaust is 2.5 inch from turbo to before muffler then stock muffler and end pipe kaya tahimik pa din.Last edited by dadz; February 23rd, 2011 at 06:55 PM.
February 23rd, 2011 06:50 PM #39
Not quite. Kasi by definition, a sleeper car is:
a car that has high performance and an unassuming exterior. Sleeper cars are termed such because their exterior looks little or no different from a standard or economy-class car. In some cases the car appears worse due to seeming neglect on the owner's part, typically referred to as "all go and no show". While appearing to be a standard or neglected car, internally they are modified to perform at higher performance levels.
In the case of your pick-up, puede siyang magka-opposite effect. Dahil sa dami ng decals, iisipin ng marami na ito'y ricer, "all show & no go." Pag kinarera nila, dun na lang nila malalaman ma may ibubuga pala nito.
February 23rd, 2011 07:26 PM #40Im a ricey with enough engine power .....................
for this?
250 hp?
[ame]www.youtube.com/watch?v=I7btbdSq9B8[/ame]Last edited by uls; February 23rd, 2011 at 07:37 PM.
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
