The recommended tire pressure for your vehicle is located in a panel near the driver's door (when you open it). Fill your tires when it is at rest (not after a long drive).
Things to look out for also:
- coolant level (this might be located near the gas tank), top-up w/ distilled h20 when it is near the low indicator
- power steering fluid level, use ATF to top-up
- battery, maintenance free ones will only last between 15-24 months
do also check for fluid leaks in your garage floor (do this by placing a newspaper underneath the engine).
check out also if all your lights are working.
hth
