Results 1 to 7 of 7
    I saw the exhibit of the 2003 Subaru Forester kanina sa Shangrila mall. And I was made curious by on of its features:
    HORIZONTALLY OPPOSED ENGINE
    Sabi nung taga GM, mas fuel efficient daw ito and mas malakas ang makina since it defies the laws of gravity daw dahil patagilid na ang takbo ng mga pistons imbis na diagonal ang set-up nito. Is this true? Galing!!! :shock: Bakit ngayon lang naisipan to???
    Anyways...curious lang po... :roll: :roll:
    Here's the price nga pala: P1,310,000 for Manual
    P1,360,000 for Automatic
    djerms::: pare boxers have been around for quite a while. Posrsches and subaru are the main proponents of these types of engines. "Defy gravity?" i dont think so. :D
    Boxers, being shorter in height compared to inline or V engines, give the car a lower center of gravity, improving handling characteristics (well, in general at least). I think this was what the salesman wanted to say. If a boxer engine defied gravity then, well heheh, we'd have flying subarus :D
    the boxer configuration by itself won't give any appreciable fuel efficiency and power benefits... what it does affect is center of gravity, and noise, vibration, and idle quality probably
    basically, the salesman is BSing you, imo
    Djerms,
    Yung diagonal set-up, Vee configuration iyon. V8, V6, B12, etc. Iba-iba din ang angles niyan. May 90 degrees, 60 degrees at kung ano-ano pa. Yung makina natin sa Trooper at Pajero ay in-line configuration meaning patayo ang mga piston as in up and down ang movement (wow, kinky! hehehe).
    Yung boxer engine nakahiga ang pistons. Kung makikita mo in action parang side to side na ang movement niya. Ginagamit din ng ibang manufacturers iyan like Porsche.
    Yep, it will lower your center of gravity. NOT defy gravity. hehehe.
    Yup. Exactly why it's called a boxer engine because of its horizontal "boxing" motion.
    checkout howstuffworks and you'll see there different types of engines. the horizontal thing isn't new at all.
    while youre at it, check out Volkswagen's W-engines (double V). More cylinders, less engine mass.
Does this make sense???
