Results 1 to 10 of 13
June 1st, 2003 05:22 PM #1
got a 93 itlog lancer glxi
its situation now is sbra na lowered dahil sa lowering sprngs then pinutulan pa ng knti..
tapos mdme siyang squeaks under and i think sa suspension..
i wud want to lifht it to stock sana..
pero pangit na tignan.. kasi naka USDM na bumpers.. un extended.. tapos 16 inch na mags. kaya prng ang taas ng labas...
dko alam ang gagawin ko.. gusto ko sana ganun parin porma pero mawawala un sqeaks.. posible ba?>
o may other suggestions kayo?
June 1st, 2003 07:04 PM #2
chong...compromised talaga yan pag lowered...
bata ka pa kasi..kaya gusto mo porma talaga...
pero habang tumatagal at tumatanda...maiisip mo na mas ok parin ang stock height...or lowered pero konti lang like my exalta.ung hindi maaapektuhan ang suspension mo.
MAMILI KA.ikaw lang makakasagot niyang tanong mo...
June 1st, 2003 07:20 PM #3
kasi baka ibenta din sometime before the year ends..
pag ibalik ko ng stock lahat parang nakakahinayang na ayaw ko na dalhin.. :mrgreen:
pero mas gusto ko na gamitin ride ng dad ko because of stock height matic pa..
anu ba ginawa mo sa suspension glenn?
maSUV nadin ako sa summer.. pero mtgal pa naman so gagamitin ko toh for haf a year.. d kasi ako makadecyd.. bago bago e..
June 2nd, 2003 05:37 AM #4
Cut pala springs mo, most likely wal na or sira na rubber dampers nyan at kumakayod na sa shock housing. try to check and install this. These are the moulded rubber seats between the shoch mounting and spring. there will be 2 in each spring one at the bottom and one at the top. Check this out since you cut your springs the spring ends will not be closed or leveled with thge shock housing so you will have an uneven contact and this is the squeecking sound that you hear.
June 2nd, 2003 02:10 PM #6
put back the stock springs and replace the shocks to just lower it mildly (1" should suffice).
if ever the springs were replaced / compressed / cut without changing your shocks to performance versions, it'll give out very soon.
June 3rd, 2003 12:05 AM #9
ahh.. un softness ng ride?.. parang stock lang ba?.
using the stock shocks?..
teka.. diba ur gonna sell it na ult?..
June 3rd, 2003 03:59 AM #10
odell,
bili ka na ng SUV..ano ba balak mo bilhin..?
benta mo na yang lancer mo!
Yaris Cross: ₱ 200,000 for S HEV Zenix: ₱ 150,000 for 2.0 Q HEV CVT
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
