Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Aug 2010
    Guys, nung isang araw pag sakay ko sa jeep, I was amazed at the jeepney driver when shifting from 2nd gear to 3rd then 4th gear, hindi na nagcclutch, then I asked my friend how is that became possible, sabi niya natural lang daw yun, clutchless shifting daw ang tawag then, I just want to try it pagnagdrive ulit ako ng M/T. Ang alam ko lang kasi kapag naka-gear ka pwede munang hugutin/i-disengage agad to neutral kahit hindi tatapak ng clutch.
    so, does anyone tried it before?
    Jul 2010
    I heard that before...posible nga yan...depende sa clutch at gear control....swertihan ang MT...me malambot at matigas na clutch pedal..minsan konting kadyot lang pasok kaagad.
    minsan kahit ilang kadyot hirap pumasok.....
    katulad ke mamang driver, kahit walang kadyot pasok na kambyo nya....
    madalas ko rin nakikita yan sa mga jeep. have not tried it though.
    Jan 2008
    given the right engine rpm, vehicle speed and timing of shift, clutchless shift is possible.. you can do that 2nd gear to 5th gear pero usually low speed mo lang magagawa kung bumibirit ka hindi pwede..
    Jul 2011
    Having driven a Nissan Urvan - konting apak lang sa clutch pwede mo na i-kambyo
    unlike sa Toyota HiAce ko ngayon - dapat mas malalim ang pagkaka apak mo sa clutch para pumasok ng smooth yung kambyo
    Jan 2008
    ^ hindi clutchless yung ginawa mo eh may konting apak ka pa eh.. ang clutchless yung nag shift ka without pressing the clutch..
    Jul 2011
    Yep, my post was a bit OT, but it still discusses shifting
    anyway, I won't try it coz kapag hindi nga sagad apak ko sa clutch tumutunog na eh, like scraping metal on metal
    Jul 2010
    oist, wag kayo mag-aaway ha...kwentuhan lang tayo about kadyut ha...
    nyahaha...tsikot word of the day yata ito....
    Hindi ba nakakasira yun? May few instances na pag mag shift ako ng gear at di ko naapakan maigi yung clutch, ang sakit pakinggan ng tunog.
    Another trivia pala, walang handbrake ang jeep. At yung view daw sa windshield very restricted. Galing nga ng jeepney driver, sana yung skills nila gamitin nila sa maayos na pagd drive.
    Magaling kumadyot yung nasakyan ni Zap. Kaya pala "Basta Driver Sweet Lover" :rofl:
    handbrake sa jeep? meron. nagpalit kami dati ng transmission sa lumang jeep namin ang handbrake nasa may transmission area.
    I meant the pampasaherong jeep. My ex mentioned before wala daw handbrake yun. Naisip ko nga how do they park pag inclined area. I took his word for it na lang. hehehe.
    Quote Originally Posted by zap.FREEDOM View Post
    Yes, I have done it. It takes a bit of practice to get the timing right with the gas pedal and shifter. And you can only do it when you are on the move, minimal traffic helps.
    But even with the best timing, you will crunch the gears which will lead to premature wear & tear. Each time you "crunch" the gears, it shaves off some metal filings into the gear oil. Do it often enough and your gear oil will be more metal than lubricant.
    Just save this for emergency driving when your clutch pedal has failed or similar.
    Dec 2002
    nakashift sa 1st gear or other gears, yan ang handbrake nila when parking. tapos yung iba lalagyan pa ng bato.
    Aug 2004
    Second this. While it's possible to time it so that you won't get a gear crunch, you will still grind them from time to time... so they'll wear down.
    On old-school rear-wheel drive diesels, the gear cogs are big and durable, so it's easy to do this... hell... the older the gearbox, the easier, as the edges of the teeth wear down over time. But with modern, compact five or six speed front-drive boxes in sedans and hatchbacks, the chances of stripping gear or synchro teeth are much higher.
    Aug 2010
    oo magaling nga siya madam Cathy, gusto ko rin mag-practice para gumaling ng ganun, hehehe!!! grabe, katabi ko yung jeepney driver na yun, then pinanood ko yung driving style niya napapatulala ako nung nag-shift na siya ng gear, saka grabe kahit clutchless ang smooth ng transition ng gears niya.
    and also about what you mentioned oo, restricted nga ang windshield ng jeepneys, kaya minsan mahirap makita yung ang traffic light na nakamount sa taas.
    so GH, kailangan din ng tamang RPM? I have doubt to try kasi nga baka ma-grind ko lang,
    may mga instances kasi, like kapag nagddrive ako ng corolla, kapag hindi sagad sa floor yung apak ko ng clutch e parang may naririning nga akong nasabit/ weak sounds of grinding gears, may be susubukan ko muna sa multicab, nakakatakot kapag sinubukan ko sa kotse talaga e,
    and also my friend mentioned when I asked him what clutchless shifting is all about, He says that it is also a lost art in driving.
    yah, Niky you're right, at first I thought that jeep was using a dog clutch pero napansin parang hindi e, kasi nagamit din siya ng clucth pag1st gear saka mag-ddown shifts, clutchless lang pagmag-uup shift, I think that jeep was some of the first models release by lawin motors pa, luma nga yung jeep na nasakyan ko, but the transmission what the f*!!!, it was so amazing. So, now I get the special ability of the old-school trannies.
    Kinda. When you shift from one gear to the next gear, you have to match engine RPM with the current speed of the tranny. It also helps to momentarily unload the engine when doing it so you dont loose too much speed or momentum.
    Lost art because most of us are now driving automatic tranny vehicles.
    What's the point of doing this? Your car has a clutch system then better use it.
    Back when I used it, my clutch cable broke. hehehe! Hence no clutch pedal action. Before that, I tried it a few times successfully, but never had to drive through EDSA as I did when my clutch cable broke.
    Generally, it saves time between shifts. Great when racing.
    Aug 2004
    Great to learn for racing, because if you can rev-match well enough to do a clutchless shift, you can shift faster even with a clutch... as you:
    1. Won't have to wait for engine speed and wheel speed to match after shifting.
    2. Won't experience shift-shock when shifting mid-corner, which means you won't upset the car's balance and potentially cause a spin.
    3. Won't wear down the clutch as quickly.
    Aug 2010
    nakakatuwa lang kasi, parang sporty din e, kaso mukhang mahirap. It's like doin' a trick while driving.
Clutchless shifting? Does anyone try it?
