Quote Originally Posted by Nyaminya View Post
Sa mga sumagot sa akin question, it seems ang gagaling na ninyo magdrive. Yes I have had a drivers license since 1997 i have been driving manual and automatic, in the philippines and in north america. My car is a honda civic 1997 AT Vti. I dont think it is driving style... normal ba na tataas un rpm kapag magaccelerate na di na aakyat ang speedometer pero un rpm tumataas pa din? Na parang nakastand still un sasakyan pero parang nakaneutral habang nagrerevolution un engine? I dont think normal yun and i have driven enough years naman na siguro to know if it is normal or not.
Sunget mo naman... kulang kulang kasi info mo kaya ganyan sagot..
Kung AT yan.. clutch slipping ang tawag dyan.. malamang between 2nd gear to 3rd gear yung slip na nararamdaman mo based sa speed mo na 30 to 40 kph..
Check your atf level, color and smell.. check level while engine is idling. cycle the shift stick to all gears. When the rad fan kicks.. check atf level between Hot zone.
Using tissue paper (white) check its color.. should be reddish in color. Then sniff the atf for any burnt oil smell
