Page 1 of 2 12 LastLast
Results 1 to 20 of 33
    Sep 2018
    2016 Toyota Avanza E CVT
    Receipt below is from Toyota Casa in the province. Curious lang, pag sa Speedy Fix instead, mga magkano kaya?
    Thanks in advance!
    Quote Originally Posted by ManicCompressio View Post
    Thanks in advance!
    baka 5k lang yan or less
    Taga!
    Pinunasan lang ng bimpo at engine wash.
    Yung rotation at balancing P50 per tyre lang yan including na tingga baka P500 may sukli ka pa pang milktea.
    Aug 2017
    Taga!
    Agreed. Sa Anonas, sa For Tire... P400 including weights (regular rims).
    Saan yung may sukling Milk Tea?
    Quote Originally Posted by SidCoronel View Post
    sa "kagalingan tyre shop".
    May 2019
    Learn to DIY. You’ll save a lot and can make sure that it’s been done properly.
    Jan 2016
    8k+ Ang lubricant/oil?
    Sent from my Mi A1 using Tapatalk
    Kaya ako kung wala corkage ang oil, i bring my own otherwise buy the cheapest oil at casa.
    Then i print my own checklist as guide ni service advisor like
    - Perform 5k PMS
    - replace lube and lube filter (customer-provided)
    - recover all consumed parts
    - replace spark-plug based on manual
    - do not include additives/washer fluids
    - no engine injector cleaning
    - no engine detailing/ flushing
    do they give you the used washer?
    i have this suspicion, "they recycle", and pocket the difference.
    in the olden days, when we used to do our oil change,
    "kuya, wag na natin tanggalin ang old washer; dagdagan na lang natin ng bago, para mas leakproof..."
    mas OK nga ba ito?
    mas OK nga ba ito?
    the recycling?
    or the double-the-washer?
    car aficionadoes would probably frown on both.
    some oil filters, may kasama nang washer sa pakete.
    i found this out, when the gas man was brandishing the washer.
    i asked, "san po galing yan?"
    "sa filter po. kasama na."
    ^They do, even the oil, and coolant. Hirap sila isalin yung oil dahil ang recovery tank nila yung 100L vessel, i let go of the fluids kung kita ko naman sa window na pinalitan nga.
    I stock these washers as they are cheapest P5-35 at local hardware than the casa. Example is this gearbox washer from toyota which is the same dimensions used but different price at Nissan, i got the copper version cheap. When I asked Nissan Quezon Ave, they don't stock daw gearbox washer because they don't replace it..haha Tansan yata ginagamit nila o Threebond lang.
    maybe their computer info on you indicates, "costumer is a bean counter. give him every single piece and drop that was replaced".
    on mine is probably "kuripot ang costumer. don't waste your breath and belay the optionals".
    anong lube kaya gamit nila no? ^_^
    Thanks in advance!
    about half price lang siguro, kung off-casa.
    even less if one opts for mineral oil. that way, one is forced to do 5K km oil change. it somehow guarantees cleaner circulating oil, compared to 10K km intervals.
    and as it's a 2016 model, it's probably off-warranty already or nearly so.
    puede na sa neighborhood gas station. no waiting doon, if one times his visits.
    Thanks in advance!
    Naholdap ka na hinubaran ka pa. 8k for 4 liters of oil? Mineral oil pa yan malamang.
    I just had 1st 1k km pm on my starex, 8 liters of fs oil, the whole 1st 1k km check up shebang for P6.2K. Kung pinaalis ko yung washing nasa 5.8k lang.
    Out of warranty naman na yan kasi 2016 pa, sa labas ka na magpa pm.
    Had my 30k PMS for my Altis. Paid 7.2k
    Speedy Fix mura lang labor for PMS
    Jan 2016
    5 liters of oil?
    Edit: googled it, 4.3 liters pala Ang capacity
    Apr 2020
    Thanks in advance!
    Actually that price is normal if you will service your vehicle inside the Dealer's casa. But it is also proven that they always charge overpriced products and services compared to those reliable casas out there. They even charge you or will tell you that you need to change this, change that even without any good/beneficial reasons. It makes me wonder maybe because we do not have any choice since we really have to service our car in the dealer's casa to aviod disqualification in the warranties.
    oil change and tire rotation/balancing?
    if you want only those in that list,
    a decent gas station and tire shop, can do it, for half the price and little or no waiting.
Casa Regular Maintenance for 12.5k, Overpriced?
