Results 1 to 10 of 12
January 19th, 2006 09:54 AM #1
anong magandang pang-rustproof sa mga nuts and bolts sa ilalim ng sasakyan, dito kasi nagsisimula ang corrosion. okey bang gamitin ang engine oil?
January 19th, 2006 10:23 AM #2
Actually, unless you replaced the bolts and nuts with substandard ones, they don't rust. Manufacturers use anodized bolts and nuts that just don't.
January 19th, 2006 10:33 AM #3
Originally Posted by theveed
January 19th, 2006 10:49 AM #6
You can use a special type of grease commonly called "pneumatic grease", mostly use in oil and gas industry to protect the bolts and nuts to fuse caused by metal corrosion/errosion.
January 19th, 2006 11:14 AM #7
spary it with "ZincIt" (zinc it) cold anodizing paint. or why not undercoat the whole underbelly of your car? winter dyan ngayon, so make it a point to wash your vehicle at least every week.
- Jun 2004
- 1,311
January 19th, 2006 11:24 AM #8Engine oil could harm the paint on the bolts (if painted) and area around it. Grease would be better.
January 19th, 2006 12:41 PM #9
Originally Posted by yebo
Originally Posted by chris_d
Sasamantalahin ko na rin po ang pagtatanong, may konting bubble ng corrosion yong likod ng rubber trim ng pinto ko at gusto kong i-grind para matanggal yong kalawang, anong dapat kong ilagay once na nagrind ko na. So bare metal na yong nakalabas, ano bang ginagamit ng mga bodyshop para dito?
mas gusto kong ako ang gumawa basta alam ko lang ang dapat gawin at least masisigurado kong tanggal lahat yong kalawang. Sa mga bodyshop okey sila kaso minsan sa kabisihan minamadali kaya after few months ayon balik na naman yong bubble. thanks.
January 19th, 2006 12:52 PM #10
merong spray-on teflon for bolts or yung rubberized undercoat in spray cans pwede rin.
sa bare metal you have to put some body-filler then lihain mo, tapos paint mo. wag mo pababayaan na exposed ang bare-metal tyak kakalawangin yan.
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
