Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Aug 2015
    Pls help. Its my first time na mag PMS na 80k kms. I have altis 07 AT, ung iba sabi change lahat ng fluids aside from usual change oil at tuneup. Is that necessary? Balak ko din palitan na serpentine belt.
    Thanks!
    Jul 2010
    Yes sir that is correct. It is required to change all fluids on your car.
    Jul 2010
    Quote Originally Posted by unmarked View Post
    Thanks!
    fluids change has a schedule. consult the manual po. if you do not have one, consult the casa.
    complete change of fluids in a newly purchased used car, is more for surety and peace of mind... just in case previous owner "manhandled" the car.
    same with that serpentine belt..
    belts have telltale signs of "time to replace".. look closely at them. if they have tiny linear cracks, even one only, replace. if you want peace of mind, replace.
    40k and 80k 120k are the same. Complete all fluid change.
    Aug 2004
    yes, change all the fluids.
    it's also good to change the serpentine belt.
    i also have a '07 1.6e altis mt and changed the belt during 60k and 120k preventive maintenance.
    Aug 2015
    Thanks sa lahat ng responses nyo. Malaki laking gastos ito. How about fuel filter? If it hasnt been changed, kelangan na din ba for peace of mind? Ala atang visual inspection to? Tama ba?
    Aug 2004
    change fuel filter every 40k.
    Aug 2015
    Quote Originally Posted by mcbry View Post
    thank you sir.
    kung ayaw ko sa CASA, san maganda/recommended to? gusto ko sana one stop shop. meron bang kaya yan lahat? pati piyesa kanila na galing? kung may alam kayo within Metro MNL pa suggest naman.
    -all fluids (engine, atf, brake, radiator, power steering)
    -all filters (oil, fuel, air)
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    Jun 2005
    thank you sir.
    -brake pads
    -serpentine belt
    thank you sir.
    -brake pads
    -serpentine belt
    gas station kayang kaya yan.
    or servitek
80k preventive maintenance
