Results 1 to 15 of 15
    May 2005
    mga mods, i have posted the same thread sa honda forum, just reposting here bec urgent ang tulong niyo. thanks.
    I have a 3 yr old 7th gen honda accord, 40t km pa lang mileage. nag lock ung automatic shift the other day, dinala ko sa sa honda alabang, ang sabi ng technician nasira daw computer box ko and needs to be replaced. ang super inis ko ka eexpire lang ng warranty ko! Is there a place where I can bring my accord to get a second opinion? i just have this feeling na niloloko lang ako ng honda alabang e by charging me too much e. thanks for your help.
    May 2007
    bro,magsecond opinion ka.wala namang masama kung ipacheck mo sa iba tutal naman eh expired na warranty mo sa casa.
    Aug 2004
    Damn... that's bad news. While it's extremely rare, it's not impossible for a box to suddenly fail. Try asking at other Honda casas... see if they'll still cover it... but you might not have any luck.
    I've heard there are some electricians who can revive a dead Honda box. But that's a risk to take only if it's proven that the box is completely fried.
    44k is about right for a brand new box... but you might get lucky and find a secondhand one. All I can say is: hunt.
    Jul 2003
    search this page for the k-test
    although the author says it is for the civic, might work for the accord.
    it is method he developed for testing the ECU. have not tried it though but it looks simple and harmless. but you need a manual (to locate the parts mentioned if ur not familiar with it) and a multi tester.
    you can browse for the reviews of the method.
    this is just an alternative method. maybe you can have you ECU check in some shops who have some spare ECU for your car.
    May 2005
    thanks guys. update ko lang kayo. i pulled it out of honda alabang and transferred it to honda magallanes, only to find out iisa pala mayari. but we know someone from the inside who thinks he can pass the ecu as under warranty. so, we will see.
    kung merun kang lawyer na friend, try mo iconsult ang opinion niya...there is no reason for that to happen (i think) unless it was a factory defect...usually a defective sensor rather than an ecu problem.
    hindi kaya nabasa ang ecu mo?
    May 2005
    Guys, I would like to share with you my experience with my shift lock problem. two weeks ago, i brought it to honda alabang to have it checked nga, they said ecu ang problem. so i pulled it out to look for a second opinion. i took it to honda magallanes, (iisa pala mayari) and naturally bec my history alabang is showing in their computer, they have to diagnose the same thing.. replace ecu. my pagka kuripot got the better of me so i decided to have a third opinion. i took it to honda manila (otis). the service advisor was very accomodating and efficient, his name is ramon severo. he took in my car and told me he suspects a switch behind the brake that may cause my shift to lock, he will diagnose and inform me asap. I didnt have to call him, he promptly called me to relay his findings, after two days of diagnosis, ecu din daw. so sabi ko palitan na lang. But he still insisted otherwise (intuition siguro nila) so he said checkin niya uli. true enough.. ung switch na sinasabi niya ang culprit, its not broken, just twisted, so he aligned it and voila, ok na lahat. I really thank him for not taking his job for granted. some technicians will just probably say, "ecu yan, palit na", but this guy really took the time to get a second pass, even if he didnt have to. KUDOS to Ramon Severo talaga, Honda Otis should be proud to have a guy like him around.
    total bill for ecu if i listened to honda alabang/magallanes.. P44,000, total amount paid by me P1,200 for labor.
    like i said...it (the ecu) is not that easy to break...unless pinasok ng tubig or nasurge ng current...most of the time it is the sensors that can cause problem that the ecu mis-interpret.
    good thing for you.
    Ramon Severo?
    When we still have the CRV naasikaso nya ko once for the 10Tkm check up. Ok nga iyan mabait. yan yung payat d ba?
    Nicknamed MON i believe
    I also have bad experience with Ayala owned Casas. Hanggang ngayon lokohan pa din PAla yang mga iyan
    May 2005
    tama ka sir maxbuwaya, si mhon nga yun. mabilis at maasikaso magtrabaho diba? sa susunod kahit malayo sa amin ang otis doon na rin ako magpa service.
    Quote Originally Posted by wildthing View Post
    good thing for you.
    Actually kahit mabasa ng tubig hindi naman.
    Last years flood "milenyo" madami sa neighbors namin nabasaan ng ECU. Some removed the batteries some did not. (Ako I removed)
    Sa tatlong Ive talk to walang nagpalit ng ECU. This things can now be fixed I believe. Alamin mo lang kung sino dapat lapitan.
    Pete,
    Good Service nga iyang Honda MAnila, pati yung Inhouse Malayan Insurance guy diyan, mabait. Siya nagasikaso ng TotalWreck Claims namin even though sa Cavite Malayan namin kinuha ang policy.
    Plus nakakapasok ako sa service Area nila. I even went sa Engine Room nila
    i meant mabasa ang loob ng ecu....ecu's are/must be sealed (as per casa).
    actually kahit na lampas ka na sa warranty you can still claim that, as to our experience with my father's 03 altis is nabutas yung gastank at nagleak, so dinala sa casa sa toyota shaw. sabi ng mga tao dun ay di na covered ng warranty since lamaps na kami ng a month or two yata then my father questioned them na, so ganito quality ng gas tanks niyo 4 years lang ang life span then mabubutas na, we had an 89 corolla and after 17 years of using it and selling it, it never had a problem like that. so kinuha nila yung altis then after 2 days ay pinabalik kami at pinalitan nila yung gas tank. imagine they are asking for 17k to replace a gas tank na mabilis magbrittle sa isang part at mabutas ng ganun lang, after that hindi na tumawag samin yung toyota para maningil ever since kahit lampas na sa warranty period namin pinagawa yon.questionable yung pagkasira nun. i hope the same thing happens to you where honda will replace your gearbox for free as well. if i'm not mistaken a/t gearbox's lifespan is around 10-15 years depending on usage.
    May 2005
    170kphlang- nothing was replaced, ayos ang ecu, ung switch lang sa ibaba ang tumabingi kaya hindi makapag padala ng signal sa ecu. actually kung ecu nga ung sira, the paperworks for warranty extension was already prepared and waiting to be filed, good thing hindi na umabot doon. But I am seriously thinking of writing the owners of honda alabang/shaw/magallanes a letter to complain about the quality of their service. I cant help but feel they are in the business to make money first, then help customers, which is the opposite of what I felt honda manila is doing. kung may malasakit ka sa customers mo first, the business will just come in.
    Sep 2004
    Naku, yung mga posts na ganito only serves to reinforce my belief na huwag masyadong magtiwala sa kasa (pero actually, kuripot din ako, hehehe).
    Anyway, nakakataba talaga ng puso yung mga mechanics na ganyan. They go the extra mile in serving the customer, at hindi palit-dito, palit-doon ang mentality.
    OT: I didn't have my 96 Sentra serviced during the first 1k PMS. Pero yung mga walastik na warranty administrator, dinetach yung coupon for the 1k PMS, when I checked the car in for the 5k PMS. I later found out na nire-reimburse pala sila ng Nissan Phils. for the 1st 20kms. Nissan Commonwealth pala yung casa
3 yr old computer box needs replacement??!
