Originally Posted by
miko101130
depende yan sir eh... vibrations on the drive train of the eve comes from worn CROSS JOINTS or FAILING CENTER BEARING.
3 cross joints ng eve, if i remember correctly, those can be changed using GMB brand, meron mazford niyan...
as for the center bearing, 3x na ako nag replace niyan... sakit ata talaga ng eve siguro... pag sira na center bearing, punit na yung rubber sa upper portion and naka sag na yung propeller sa bottom portion nung center bearing...
if indead sira na nga yung rubber, usually mangiginig yan upon deceleration or braking conditions, unlike the cross joints which vibrates upon acceleration mostly...
bumili ako dati replacement center bearing sa banawe, ok naman kaso dapat yung pang eve talaga... dapat pag bibili ka replacement dala mo sample so ma-compare mo visually if match sila sa bolt and dimensions...
ang casa if tama pagka alala ko ay hindi nagbebenta ng center bearing alone!! they will sell you the whole transmission driveline assembly costing roughly 30k plus....!!! thats why mapapabili ka sa labas ng replacement...
ok naman ang replacement sir na center bearing basta dala mo sample, yan din dilemma ko before, now replacement nakakabit sakin and 20,000 kms have past and ok pa naman... its around 3-4k ata before... my eve is already at 120,000 kms and 3x na palit center bearing, lahat replacement lang... and nag off road pa ako, tapos medyo heavy foot din sa accelerator...haha...
just an advice, if papatangal nyo yung driveline sa mga shops, be sure na kilala o suki nyo. kasi meh procedure sa pagkalas... baka ma-damage kasi yung driveline pag di maingat, usually kasi papaluin at pukpukin para mahugot yung sa meh center bearing..
