Originally Posted by
dennis powell
warren kumsta na ang ford lynx mo?,ok na ba i mean naayos na ba? if di pa eh meron akong kunting share sa iyo sa problema mo,eh kung ang idle ng kotse mo ay taas baba,epacheck mo daw yung pcv valve (possitive crankcase ventelation)maaring yan ay clogged or leak,im sure na ang kotse mo ay equiped nito,kahit ikaw puede mo gawin to and simple lang,,,,una,,,hanapin mo ang pcv valve,usually between head cover and intake snorkle,may hose yan,if di mo alam,paturo ka nalang sa mekaniko kung saan,,ang gawin mo,tanggalin mo ang pcv valve then shake it.if the pcv valve does not rattle when shaken,,replace the valve,,.2nd,,,start the engine and place your finger over the end of the valve.with the airflow stopped,,mafeel mo yung suction and engine idle speed mag drop about 40-90 rpm.if you connot feel the vacuum,,the pcv valve or hose might be plugged with sludge,if the engine rpm drops more than 40- 90 rpm and the engine begins to idle smoothly,the pcv valve could be stuck open,,so ang magandang gawin,,check mo ang pcv valve,, cehck the hoses,,wag ka munang mgjump kaagad sa mga sinasabi ng mga mechanico,...i hope it help you out..
