Hi guys,
I'm interested on buying someone's 2006 ford everest at.
its already around 160k mileage.
what can I expect with the vehicle pros and cons.
what normally wears out or I would expect to be worn out
Thanks in advance!
Hi guys,
Thanks in advance!
Medyo mataas mileage niya... I own a ford everest 2005 sir... Madali naman siya i maintain, usual maintenance lang...
Fluids, belts, adjustment ng valve clearance... If its automatic, regular atf change must be done every 40k...
Check for any leaks and history of overheating
- - - Updated - - -
I know one who owns an Everest 2005 with 300K++ Km and still running smoothly.
ok thanks po sa advice! anu-ano rin po mga problems that I have to watch out for. I previously had a 2006 xtrail na bigla na lang nasira fuel pump at only 24k on its mileage clock . thanks again
- - - Updated - - -
If possilbe, alamin mo kung anong mga parts ang napalitan na at kelan. Shock absorbers, fans, window regulators, alternators, aircon parts, etc.. Sa 160K mileage, may mga bibigay sa mga yan anytime soon pag di pa sila napapalitan from original parts.
turbo... check the turbo if meh oil leak...
check mo if mausok siya sa morning start ups at kapag mausok pag nag accelerate(not too heavy on the pedal)
check for any unusual noises during start up
check if one click sa umaga at instant ang start ng engine upon ignition sa key...
check mo battery at alternator readings
ask mo owner kelan napalitan timing belt, and accessory belts, kung napalitan ng glowplugs, at kung napalitan na underchassis like tie rods, upper and lower ball joints.... inspect mo steering play...
its better if payagan ka ma-test drive... at least you can gauge and feel the vehicle...
- - - Updated - - -
