Results 1 to 8 of 8
December 30th, 2010 01:37 AM #1
Hi Friends!
A few days ago I found it strange that after turning off the engine, the radiator fan kept spinning. I started the engine and turned it off again. The fan went off.
Doing some research I found this:
http://www.team-bhp.com/forum/technical-stuff/64617-ford-fiesta-engine-off-but-some-other-motor.html
Have any of you experienced the same? Is this true for you owners of other brand/models?
Do you think it is feature or a glitch?
- Jan 2008
- 4,726
December 30th, 2010 01:40 AM #2normal naman yan kasi mainit pa ang engine baka naka trigger pa yung thermoswitch..
December 30th, 2010 07:26 AM #3
Yeah perfectly normal yan, the ECU will detect naman if the fan needs to be spinning depending on the heat even of the engine is off already...
- Jul 2010
- 165
December 30th, 2010 09:49 AM #5No need to worry sir. That is normal, even the VW's has these even if you have locked your car the fans are still running.
December 30th, 2010 09:49 AM #6
not an owner of Fiesta pero kahit anong auto na ang fan ay electrical powered (not belt driven) and controlled ng thermoswitch, then normal lang ito.
but if after a quite some minutes na ganun pa rin, hindi na normal iyon, observe niyo sir, dapat mamatay din iyon kaagad.
December 30th, 2010 11:19 AM #7
Xiaomi E-Car
