Page 743 of 778 FirstFirst ... 643693733739740741742743744745746747753 ... LastLast
Results 7,421 to 7,430 of 7777
    Jun 2011
    #7421
    Quote Originally Posted by cend View Post
    Bro how much for complete hitch receiver w/ tow ball. (Eve 3.2 totl)
    May parating ako... Dec. Rear nudge with hitch same sa supplier ni Overland... Pero mas malaking pipe ang gagamitin ko.... You can check iba kung items sa Fb Gideon Manaen car Accesories
    Sent from my BLA-L29 using Tapatalk
    Jun 2011
    #7422
    Quote Originally Posted by alrorskyz View Post
    If you change to led, you need also to changes settings through forscan, otherwise it will be detected as a busted light bulb
    Sent from my SM-A720F using Tapatalk
    Just use Canbus... No need to change settings... And hindi naman nababago settings sa forscan... You can only turn it on and off.. Or disable or enable...
    Jun 2011
    #7423
    May malfunction kanina morning ang left signal lights ko. Mabilis ang flashing indicating a busted bulb pero ok naman siya pag hazard lights. I checked it was the front left signal that was not lighting up, left signal or hazards on. But this afternoon ok na siya. I checked umiilaw na. I pulled out the bulb holder i could not find anything wrong.
    Gremlins.
    Btw, P21Y ang bulb.
    If Led bulb... Baka baliktad pag install... Pos. And negative.
    #7424
    Ordinary incandescent lang na p21 yung front signal lights bossing.
    Re changing to leds, i already changed to led the bulbs on the sun visor vanity lights wala naman error. I don't think ford will bother having settimgs for light bulbs.
    #7425
    if baligtad pag-install, it will be consistently dark and not intermittent.
    yebo's experience is actually common.
    i just pull out my bulb and clean the electrical contacts of both bulb and socket, using a pencil's eraser.
    and wait for it to happen again. heh heh.
    Oct 2003
    #7426
    May clearance/rubbing issues ba if nagpalit into 275/55r20 on stock rims?
    Mahirap maghanap nung 265/50r20 eh. Parang goodyear lang ung option so far.
    Aug 2017
    #7427
    Quote Originally Posted by zechs View Post
    Try nitto terra they have 265/50r20 as other option
    Sent from my Pocophone using Tapatalk
    #7428
    WALA. Naka 275/55r20 ako on stock wheels since new.
    Oct 2003
    #7429
    Thanks. At least may option na iba kung walang 265/50r20.
    Nitto terra is a/t tire, might be a little noisy pag sa highway?
    Ung stock tires i think h/t or all season?
    #7430
    H/T yung stock tires.
    Meron 275/55 na achilles, accelera, thunderer, kumho. Average price nasa 8.5k each. Meron pa bargain sa olx 2 months ago na 7.8k kaya lang nasa 2016 mfg. date. Nabili na yata.
    Bad experience ko sa nitto. Mahina ang side wall, madali lang mapudpod. My ride now has 38k km, asking for replacement na ang 2 front tires. Pero maganda ang kapit at tahimik.
    Meron chinese na saffiro, toyomoto and blacklion. Nasa 4.2k - 4.6k ang price. Walang sisihan.
    Btw, mas accurate ang speedometer pag 275/55. Sakto sa gps yung speed and odo reading nung nagpalit ako to 275/55.
Ford Everest 2015
