Page 246 of 254 FirstFirst ... 146196236242243244245246247248249250 ... LastLast
Results 4,901 to 4,920 of 7777
    Mar 2004
    Stalkers do not like DRLs ...
    Oct 2003
    Kaya nga si "joe", old school ung car nya eh....hehe
    Jun 2011
    Quote Originally Posted by zechs View Post
    Giveaway ung DRL kung naka-idle ka lang somewhere like outside of the house of a patient in my case. Hehe maganda sana kung may off button lang siya. I mean its always on by default when you start your car, then off button lang if you want it turned off.
    You can turn it off using Forscan
    Sent from my BLA-L29 using Tapatalk
    Has anyone experienced yung continuous alert sound ng Blind Spot Information System or Cross Traffic Alert (not sure which one) even if ignition switch is in OFF? Pinatay ko na lahat ng Driving Aid via information display pero tumutunog pa din. Actually, di ko talaga kabisado driving aids,sensors ng Everest so di ko sure kung mapapatay ko dun. Haha. Pero upon restarting the engine, nawala na yung sound. What caused it kaya? Ang tinis pa naman nung sound. Sakit sa tenga.
    Jun 2010
    Quote Originally Posted by marky2115 View Post
    hindi ba sound ng sensor pag nag reverse ka at may malapit na object or seatbelt chime?
    Sent from my RNE-L22 using Tapatalk
    Jun 2011
    Just back it up.. Untill it sense an object... Then forward ka na.. Wala na yun
    Mar 2007
    Twice ko na na experience ang ganito sa everest namin. Ayaw huminto ng titititititit
    Nov 2017
    Quote Originally Posted by suysuy View Post
    Did you try cleaning yung mga sensors?
    Jun 2010
    need to reverse hanggang may ma sense sya ulit, back to normal na yan,
    Sound ng sensor nga. Di ba nadidisable yun? Sorry kung mali yung feature na nasabi ko. Basta yung sound na tumutunog kapag may kotse or motor na dumaan malapit sa Everest. Yung may nagfflash pa sa infotainment kung nasaan yung sensor na nakadetect
    Oct 2003
    Pwede mo i-disable. Nasa may gear shifter ung button.
    Blind spot monitoring nga yun.
    Jun 2010
    pwede sya disable, yung button malapit sa lever gear, but why?
    Nadisable ko na. I wanted to disable it that time kasi nga di nawala yung sound even if nakatanggal na susi. Nawala lang nung nirestart ko makina. Pero matagal na ko annoyed sa blind spot monitoring na yun dahil sa ingay pag may dumaan or may nadaan lang sa gilid.
    Oct 2017
    query lang mga master, pwede po ba gamitin ang CTEK CT5 start/stop battery charger sa fomoco battery ng everest? Thanks in advance.
    Jun 2010
    usually nangyayari yung continues sound pag umaatras ka, tapos pag lagay mo sa drive, andun pa din yung sound, gawin mo iatras mo ulit tapos dapat meron syang ma detect, then pag lagay mo sa drive, mag ok na sya. kahit I off mo engine ng matagal, di matatanggal ang sound..
    Jul 2016
    Update ko lang, 3years old and 35k mileage na eve ko on orig fomoco battery. No issues.
    Full charge ko lang lagi using external battery charger once or twice a month.
    Quote Originally Posted by Janemar View Post
    longest battery life on an eve
    Oct 2003
    Ganito ba ung binebenta na rear plate holder for the everest?
    Jun 2010
    may naka premium plus ba dito na nag upgrade ng headlight bulb to led (low and high beam)?
Ford Everest 2015
