Page 226 of 254 FirstFirst ... 126176216222223224225226227228229230236 ... LastLast
Results 4,501 to 4,520 of 7777
    Jun 2010
    Quote Originally Posted by zechs View Post
    Finally got the time to install the protector plate for the EPS motor
    To protect the arrowed part:
    Ang dumi ng pang ilalim ko. Haha. Kailangan punasan.
    ano itsura nung eps protector plate sir?
    Sent from my RNE-L22 using Tapatalk
    May 2007
    ano magandang battery pamalit sa stock? may gagawin pa ba kung hindi orig yung gagamitin na kapalit na battery brand, like disable something via forscan?
    ^^^ ako din i just had 30k km pm done. my eve's battery is already at just 51% capacity according to their battery test. does the eve require a particular battery type? all i know is the size is 3sm.
    Jun 2017
    Quote Originally Posted by eido View Post
    Eido, yung brod in law ko same unit Everest titanium, bumigay battery wala pa 1 year, buti na lang sakop pa ng warranty.
    Jun 2010
    sir, ano itsura nung protector plate?
    Oct 2003
    Reposting
    Skid plate usually is made of steel to protect the oil pan when off-roading. This one looks like a splash guard.
    Feb 2003
    Boss, saan mo nascore yan EPS protector and how.much? OEM ba to ng Ford or aftermarket? Me abang na ba pagkakabitan or need to drill holes for the mounting screw/bolts? Sorry dami tanong...gusto ko din protect yan EPS...its very expensive pag nasira yan.
    ..I guess its IP67 RATING naman kse they claim na pede wading depth na it is subjected to full immersion
    That metal will somehow protect sa bumps
    Jun 2017
    Ford adds Waze navigation to Sync 3 platform - Pocket-lint
    Oct 2003
    *jiggs,
    Ford original part. You have to buy the screws and washers. You need 4.
    Ito ung part number: EB3C 5B018 AB
    Feb 2003
    *jiggs,
    Oks.thanks and am assuming available locally? will check.ke Fordmaz thanks sa part#....magkano ba?
    Oct 2003
    *jiggs,
    You can order the part at any Ford casa. If they have stock sa planta then good. Kung wala, they have to order it sa thailand pa. Not sure if FordMaz has that part though.
    Feb 2007
    Guys do you know the paint code of the White Everest? Blank kc paintcode sa door. Thanks
    Jun 2017
    Bad trip kahapon, nabunggo rear bumper ko ng tricycle. Nung tiningnan ko, sabi ng tricycle driver, biglaan daw kasi hinto ko. Napangiti na lang ako kahit nakita ko na meron dimple dent tsaka small scratches sa ilalim ng bumper (sa silver Grey part).
    Pwede ba Paintless dent repair sa
    Quote Originally Posted by hi5 View Post
    The plastic part... if you can reach it from the underside of the car, may way yun... youtube mo yung paintless dent repair for plastic bumpers w/ hot water.
    Jun 2017
    Quote Originally Posted by mda View Post
    Naputol yung post ko pero nakuha mo pa rin. Thank you sir!
    Jun 2010
    ganyan talaga sir, kasalanan mo pa bakit ka nag break.. minsan kahit anong ingat natin, meron ung mga barumbado talaga na di na natin control, ingat po sa susunod..
    Jun 2017
    Quote Originally Posted by gomez_ea2 View Post
    Oo nga eh nung nakita ko sa rear view ko na tricycle, bumaba lang talaga ako to check yung damage, buti na lang maliit lang.
    Jun 2010
    no need sir for reset kung palit ng battery. plug and play lang po..
    Jan 2011
    Everest titanium awd ko ay going to 2 years this coming April. Odo reading is 42k km na. So far one click pa rin sa pag start and cranking during start still good. Bukas check ko kung ano reading ng battery while engine is off.
Ford Everest 2015
