Page 208 of 254 FirstFirst ... 108158198204205206207208209210211212218 ... LastLast
Results 4,141 to 4,160 of 7777
    Jun 2008
    Quote Originally Posted by boinkssayo View Post
    Yes. Trend has Sync3 which is needed for Android Auto / Apple Carplay.
    Ok thanks
    Jun 2017
    Correct me if I'm wrong. While driving on my way home, I noticed na sobra lakas ng hatak, even at uphill sa Sumulong. Tsaka hindi bumababa sa 1500rpm kahit di nakaapak sa accelerator pedal.
    Nung humito ako para Ilagay sa Neutral ang gear, nasa S pala. All the while, I thought na pag nasa S mode, kailangan ko pa laruin sa + - manually para umangat ang gear. Pero hindi pala.
    Parang sa Juke ko rin pala na meron Sports mode.
    May 2011
    Quote Originally Posted by hi5 View Post
    Yes. Until you use it manually.
    Sent from my SM-G925F using Tsikot Forums mobile app
    May 2007
    yan din intindi ko sa sports mode. pero hindi ko pa na try
    May 2007
    napagana ko na yung rear cam. thank you sa mga kinulit ko
    panget lang ng resolution kse chipipay yung cam
    Mar 2016
    Quote Originally Posted by eido View Post
    Nice to hear Paps.. Next move syempre upgrade mo na yung camera mismo.. Pwede na isama sa list yan..
    Sent from my F3212 using Tsikot Forums mobile app
    Oct 2003
    *eido
    Does the line move with the steering wheel? Or just straight?
    May 2007
    *ArchiDeos
    Ok na muna ako dyan hehe
    *zechs
    Straight lang. Yung oem cam ata yung lumiliko
    Sep 2016
    Hi Sir,
    Paano po yan? Pwede paturo, new Trend owner here. Thanks po.
    May 2007
    Quote Originally Posted by AspiringDon View Post
    Hi Sir,
    check mo to
    Ford Everest 2015
    yung binili ko na elm yung sa aliexpress
    Buy Products Online from China Wholesalers at Aliexpress.com
    Next year!
    Ford Australia has started testing the facelifted version of Everest, which is known as Endeavour in India. According to the recent spy shots by Car Advice, the Everest or Endeavour will get updates to the front including the LED DRL's and a new grille inspired by the Ford F-150 truck. The Australian spec version of the Endeavour will get radar cruise control with autonomous emergency braking (AEB), however, the Indian spec might not carry these safety aids.
    The 2018 Endeavour is expected to use the same powertrain as in the current generation Endeavour and will be powered by two diesel engines- 2.2 litre and 3.2 litre. The 2.2 litre engine delivers 158 hp of power and 385 Nm of torque,while the 3.2 litre engine produces 198 hp of power and 470 Nm of torque. The smaller engine comes with a 6-speed manual and automatic transmission, while the 3.2 litre diesel unit comes only with an 6-speed automatic transmission. The top end diesel also comes with an all wheel drive and a Terrain Management System.
    May 2007
    hindi nag work forscan off road sa trend variant. hinahanap yung front cam. nag ka dtc error. meron nakapag enable ng off road sa trend variant?
    Sep 2016
    Thanks boss, you're the man [emoji106]
    May 2007
    1.7k pala check ko resibo. 200 additional cable.
    sa titanium may setting to turn off drl sa dash setting?
    Apr 2009
    wala. you gotta do it thru Forscan.
    Question lang po. May nagpalagay ba ng screen protector or tempered glass sa head unit nila? Yung tulad po ng link sa baba.
    Galleon - LFOTPP Ford Focus Edge Everest Explorer Taurus Car Navigation Screen Protector Glass, Tempered Glass Center Touch Screen Protector Against Scratch High Clarity.
    May 2007
    Quote Originally Posted by ferrarifan View Post
    Sa thailand ford everest forum na enable nila drl control via ipc/dashboard. Pero mukhang pang titanium lang.
    Jul 2017
    Hi, I'm not sure if this is a noob question but I'll ask anyway. Mavovoid po ba ang warranty kapag nagpakabit ng led step sills sa Trend? Thank you.
    why do you need an led step sill?
    oo nga, it's the least you see nor need. i have a titanium premium, i do not even notice that led step sill and i bet not even 1 of my family know it's there. i think a puddle/courtesy lights will be more practical than led step sills. yun kasing puddle lights sa ibaba ng side mirrors halos useless. mas maganda sana kung ang placement nya e under the doors or under the step boards.
Ford Everest 2015
