Normal ba na pag on mo ng aircon, after 5 seconds pa lalabas air sa vent, tapos medyo amoy usok ang unang labas?
does anyone know how to replace the bulbs of the sunvisor vanity mirrors? ang labo kasi so i want to replace them with leds. na check ko na sa manual wala eh, meron lang instructions mga ibang internal lights pero wala yung vanity mirror lights. i tried prying it open ayaw. may secret procedure ba?
i got it opened. sungkit lang ng flat screwdriver. nakakatakot lang baka kasi mabasag yung glass. the bulbs are fuse bulbs size 29mm x 6.3 mm. i found 4 sellers in lazada. ingat lang, 1seems cheaper than the rest but package is only 1 pc per order while the others offer 10 pcs per order at a slightly higher price.
Mga Sirs, question lang dun sa mga nagpakabit ng shark fin antenna as replacement dun sa antenna natin na takaw sabit sa low parking spaces di naman po ba siya nagka-problem sa signal or tuning ng radio? TIA.![]()
kahit walang antenna ok ang reception. i had to remove the antenna one time going north (i moved the roof rack farther back and it was in the way of the rack). same pa din with or without antenna pag dating ng tarlac wala na signal ang fm radio na manila stations.
as an option to shark fin, meron short rubber duckie/bee sting antenna.
Try shark fin, the reception is still good.
share ko lang. after 10,000km PMS, pinalitan ng Ford Cainta ang A/C air filter, worth 2500. hindi ako mapakali kaya I checked.
I think the newly replaced filter is just an ordinary particulate air filter, while the old filter is a carbon air filter. binalik ko un old filter kc ok pa naman sya. tinago ko lang muna un bago.
I think I posted it somewhere here na sa thread.
OEM cabin filter w/o carbon is 700-800 ata. Same sa pinalit sa yo ng casa.
Yung with activated carbon/blackish color, ViC Japan brand(yes, same manufacturer ng suki mong oil filter.) is 1500 same quality with our Original filter.
Edit: with charcoal black coating to absorb moisture and kill molds and germs in evap coil para iwas mabahong amoy pag on mo ng AC sa umaga... LOL.
Share my experience with my Trend,
We've gone to Isabela from QC, 411 kms, 11.8 km/L lng nakuha ko. 80% highway max speed at 120kph. Masarap hatawin sa nlex sctex at tplex.
May konting sound ka tlaga marinig galing rain visor if you more than 100kph.
Parang hirap sya from 20kph-50kph lalo kpag paahon sa bundok. 3 passengers lang kami. 31psi harap 35 sa likod. Hndi nman hirap na hirap pero parang hataw muna makina with extra garble sound. Normal ba un? Naisip ko paano na pag pabalik, mas marami ang uphill tapos zigzag pa.
Naka medium tint ako aa harap, wala akong makita sa lakas ng ulan one time. Balak kong patanggal nalang in time.
Anyways, in general, all is good. Maliban lng sa parang un ingay ng makina sa low gear.
I tried S mode, hndi pa ako sanay.
Additional experience,
There are times na matigas apakan un break when about to start the engine. As in hindi mo sya ma press all the way. Konting apak lng kaya,pero na iistart parin engine, then after that malambot na ulit?? Normal ba un?? Mga 3-4 times naranasan ko. I did follow the handbreak in N before going to P. I tried on and off unit pero matigas parin. Anyone experience it or paano gawin??
Sir Janemar, query lang though nabasa ko kasi sa fcp forum that you planned to have your interior trims (e.g. door handles, sidings, center console) foiled to prevent scratches. If you don't mind me asking natuloy po ba ninyo yung pag-pafoil po ninyo, how much po if ever and saan? TIA.
