Tanung lang, ano ba meron sa sync 3, 1st ford ko kasi ung eve, kaya wala ako idea sa mga sync nila.. ung nsa eve nga ngayon parang ok na sa akin.. although nothing special din naman.. sa simula lang pero after a while, wala na din, parang mobile phone.. daming features pero at the end of the day, you can libe with call and text lang naman.. the rest kahit wala, ok din naman.. sorry po sa mga sync 3 fans, di ko lang kasi kabisado mga features kung ano meron..
Sent from my ASUS_T00J using Tapatalk
What can you expect from a 3.2 engine. That's roughly 10L of oil at say P700 per liter plus the oil filter at 1k++ ??
Though the 3500 air filter is too much. Cge mamya check ko kung gano kalaki air filter ng ranger. Pero since casa times two sa banawe, P 1.75k sa labas.
The Everest / Ranger require the FS 5W-30 for diesel. I dunno if meron na shell neto, usually sa mga gasolinahan. 15w40 or 10w30 for diesels
Una ko pa lang na-receive company ranger ko, sabi ko na nga ba madugo ang PMS neto, good thingg my company foots the bill.
_________________________________
If you are wrong, turn right.
If you are right, turn left.
Afaik, walang code ang paint ng ford, kahit saan mo tignan, sa may pinto, under the hood, wala, patimpla mo na lang sa magaling mag halo, madali lng naman gayahin ung trim na yan..
Ford Quick Tips: #29 What A Failing Electronic Steering Gear Sounds Like - YouTube
I'm planning to get an everest on December, and while doing some research, I happen to see this EPAS problem in ford F150. It's kind of worrying if that suddenly happened while driving in a zigzag road. Everest and explorer are also equipped with EPAS.
Electronic steering is withbford for so many years now, if im not mistaken its with the 1st gen expedition, so this is not new with ford, so nothing to worry about (pero syempre may chance pa din na masira agad or sira ung mapunta syo, di naman natin maiaalis un kahit saang model and brand even its brand new). But for that technology, matagal na yan sa ford, pag nasubukan mo na ung electronic steering, sarap lalo sa traffic and parking, even on cruising, very relaxing.. another plus for the everest.. hehehe
for titanium plus owners, has anyone had the moon roof tinted already? what brand and what shade did you have installed? i'm asking because these days when the sun goes out it is quite intense and i can feel the heat radiating from the moon roof.
Anyone here have ignition starting problem?
2nd time na ayaw mag-start ambiente ng sister ko. First time was resolve thru jump starting by the truck from their road assistance. Hindi kinaya mag jump start nung other car nila.
Was the battery different from other variants?
During my 1k PMS, yan nga ang madalas na issue sa ranger/everest sabi ng mechanic. Habang waiting, mga 3 units ng eve ung dumating sakay ng flatbed all dead bat problems. Anyway, first of all check mo muna on your side. Baka fault mo rin. May naiiwan ba kayo gamit na naka plug sa 12v outlet pag iniwan na oto or baka may naiiwan na bukas na ilaw.. basic cause yan.
A few notes;
- May 1year warranty battery natin so pede mo sched sa casa for replacement.
- our batteries are Calcium-Ca Type, instead of lead Antimony type na usual na benta ng motolite. So yes, technically kakaiba sya sa common sa market. Ca-ca is much stronger, can tolerate high charging voltage up to 15VDC.(sa ordinary motolite gold or excel, mag evaporate na tubig nyan at masisira na.)
Locally, alam ko is bosch lang ang meron nito. Amaron not sure too if CaCa sya...
- Given na Ca-ca type batteries natin, mas matibay sya to cope up with our Ford smart charging system. Basically, kakaiba ung alternator natin. Compared to usual na alternator pag start mo pa lang ng oto charge na agad sya to full potential.
Sa atin, may ammeter naka series sa battery para mapick up ung actual electrical load ng system and ma adjust accordingly ung ibibigay na charging amperage/power ni alternator. Also, factor in din nya ung driving condition like if decceleration or idle, di sya mag charge ng battery to save on fuel.
The list will go on pero basically it will save fuel and prolong alternator life. Google na lang din if you want more info.
Sa aussie forums, marami ang nagpadeactivate na nyan smart charging system dahil marami rin nagrereklamo dun na dead bat... Pede mo pa request sa casa deactivate nung feature or may aalisin lang na cable(forgot the exact pin, google na lang din) or I can do it for you just PM me, i package ko removal ng annoying door open chime. Hehe..
miniOB, sarado na yung cover mainit pa din.
gomez, thanks. i just did some googling and some say moonroof will crack due to heat retention of the tinted glass, some say otherwise. anyway i am leaning towards privacy/mirror tint.
