Results 1 to 8 of 8
- May 2006
- 9
April 28th, 2008 12:37 AM #1Am Gasoline are really going high right now. So I switch to Super Unleaded, before I was using V-power. Is't ok if I fill my car with Super unleaded gasoline with 93octane rather than V-Power 95octane? Info I read the manual of my car is says 95octane. Is filling my car with Unleaded with 93octane bad for my car?
April 28th, 2008 03:03 PM #2
It should be okay. New 1.8 Ghia or an older one? If you've had the factory reflash (ask your dealer), then it should have no problems on Unleaded.
April 29th, 2008 03:52 PM #3
It won't hurt if you use 93 RON.. but it would be better if you fill-up with 95 octane gas. I believe 95 RON is the recommended fuel to use with the FOCUS engine.
April 29th, 2008 03:57 PM #4
yup its 95 ron (recommended sa manual). had the opportunity to drive one. pero pede pa rin 93 ron.
April 29th, 2008 03:58 PM #5
imho, new cars today can run on 93 RON.
but since fuel is expensive now. why not try it at first? then check how your engine behaves and if you are not really contented with it, then its up to you to go back to 95 RON.
the reason why its recommended in the manual is because they are projecting engine performance for optimal results. and i guess even though you use a lower octaned fuel, wala namang masisira yan sa engine.
- May 2006
- 9
May 2nd, 2008 06:38 PM #7
Sorry kung medyo OT pero pwede ba sa Explorer yung V-Power? Kasi may kilala akong owner ng Expedition na nasira daw yung engine dahil sa taas ng octane ng V-Power. Eh diba kumang makina parin yung makina ng Expe at Explo?
Ang sabi saken mag Caltex Silver daw. Pero Super Unleaded gamit ko ngayon.
Daming issue ng SU7:grin:
Xiaomi E-Car
