Results 1 to 10 of 26
February 22nd, 2021 10:42 PM #1
Doc, if you're referring to the shape where the bracket comes down from the battery sensor towards the battery pole, you'll be surprised to know, they're replacing it with the same design. But they took out that other branch that goes the other way and grounded to the CVT.
Sent from my Mi A1 using Tsikot Forums mobile app
- 54,206
February 23rd, 2021 12:07 AM #2highs!
it'll probably last longer, but will still fracture just the same.
it's still the same lollipop design!
lollipop. relatively thin, light bracket, heavy head.
in the olden days,
the battery terminal was connected to a long, flexible cable that did not mind vibrations...
- Nov 2019
- 1,407
February 23rd, 2021 12:46 AM #3
- Jan 2007
- 2,587
February 23rd, 2021 01:33 AM #4
Actually seems like an easy DIY (temporary) fix if it breaks on the road, even if you don't have the extra part. Length of wire lang to connect the battery terminal to the part that broke off.
Luckily both parts already have a screw that you can connect a loop of wire to, all you need to carry is a small length of wire and a 10mm socket (or whatever fits, or pliers)
If you want to do something pre-emptive maybe wire the two points together in advance, just use some thick grounding wire with spade connectors.
Log into Facebook Ganyan ung bollard..anti pushcart lang talaga siya
