Page 6 of 8 FirstFirst ... 2345678 LastLast
Results 101 to 120 of 366
    Based on data sheet. X9000 will result to better FC. The x7 is too thick at operating temps...
    Baliktad.. lmao
    15.33 vs 15.04(x7) lower results to better fc
    Good luck
    Sulit price ng X7, even the X9. I might use the X9 on my FXT on its next oil change. For my Fiesta, I will use the X7 5w20.
    Aug 2005
    Im using ZIC X7 for my diesel Car so far so good satisfied ZIC user ako
    Apr 2012
    Wala ba kayo nagiging problem sa 30 weighed oil kahit summer o madalas sa traffic? Tempting to use on nxt oil change [emoji16]
    Sent from my SM-J730G using Tapatalk
    Wala naman ako issue in using 30 weight oil. In fact, the engine of my cars require 30 weight oil. I use Zic X7 5w30 on my FXT and I will be using the same for my Fiesta's next oil change.
    Apr 2012
    My starex advised according to the manual 5w30, 10w30 and 15w40
    But kinda hesitant to use 30 weight oil [emoji16]
    Someones encourage me please [emoji16]
    I see 41c temps and my 10w30 semi synth oil is perfectly fine.
    Apr 2012
    Thanks, Ph weather never reaches 41c i think.. Lol
    bro the cooling system will handle this easily. there is a thermostat that opens when the coolant reaches 87-91c. this is rather old technology almost like non-inverter air conditioners(on off). the radiator and fan can cool easily an engine that is only idling in traffic thats only around 2kw. and full power around 90kw? thats easy for a properly designed cooling system.
    newer engine cooling systems now have variable speed water pumps(non belt driven) and electronic thermostoats. theyre more like inverter type air conditioners(variable). names like dynamic force from toyota and smart stream from hyundai and kia feature this variable cooling system. this maximizes thermal efficiency and affects fuel consumption.
    Oct 2013
    I bought an x7 and x9.
    Nakalagay sa likod ng x7 na fully symthetic blend motor oil while nakalagay sa X9 na fully synthetic motor oil.
    Does th8s mean that x7 is a semi synthetic oil?
    Oct 2018
    i drive a 2013 everest. changed oil to X7, noticed that the engine became noisier and may vibration on idle. actually not sure if its engine oil related, but yung engine supports are ok. ang mga pinalitan lang prior to the issue was change oil and belts
    I don't know with the experience of others but I have no issues using the X7 on my FXT.
    Quote Originally Posted by bogart.2006 View Post
    what viscosity 10w30 10w40?
    Oct 2018
    10w40 sir
    Jan 2008
    Hindi naman sa cold start lang un comparo nya. Kahit pag mainit na ang makina.
    Kahit un shell helix ultra 5w30 at amsoil SS 5w30, mas tahimik un amsoil mapacold start o pag normal operating temp, pati sa high revs. Sempre same car, Mazda skyactiv
    Sent from my Redmi Note 5 using Tapatalk
    Jul 2013
    Quote Originally Posted by kkreuk18 View Post
    I suggest you study or google muna what those numbers mean.
    Sent from my ASUS_X008D using Tapatalk
    So far, I have had no issues using the Zic X7 5w30 FS oil on my rides. I use my rides frequently and I am not the timid one on the highway. I have used on solely on turbocharged engines but I have just used it on an NA engine (Mitsu 4B11).
    Jan 2008
    Quote Originally Posted by Lew_Alcindor View Post
    Di ko nagets. Hahaha! Im just comparing 2 brands with the same viscosity. Mobil vs zic, shell vs amsoil
    Sep 2013
    Bumibili ako ng magnatec pang change oil wala, ZIC 10w-40 lang meron mas mura kya binili ko na, pagtingin ko fully synthetic pa[emoji38], ok ba ito mga lodi?
Zic engine oil
