Results 1 to 10 of 21
- Oct 2008
- 469
October 23rd, 2008 10:59 PM #1Mga Guru's ask ko lang po sana kung bakit po kaya after mga 5 mins of reving up, nagkakaroon po ng medyo white smoke sa tambutso ko po, tsaka medyo umaamoy ng unting fuel/oil. Hindi po kaya dahil sa hindi pa ko nagpapa change oil and tune up?? anuh po kaya problem? My ride is sentra eccs Tnx..
October 23rd, 2008 11:04 PM #2
- Oct 2008
- 469
October 24th, 2008 03:15 AM #3Ai ganun po. wala naman po ko napapansin na leaks sa makina. Napapansin ko lang minsan yung medyo may white smoke tsaka medyo lumalakas ang FC ko po. Pagkano po yung Piston Ring?? Pagkano po kaya aabutin paayos sa mga headgasket, etc?? Tnx for ur input sir.
October 24th, 2008 06:18 AM #4
If it is white smoke the head gasket gone. unfortunately you wil have to take the head off and replace a new one!
If it is blue smoke your burning oil because on your engine needs new valve seals, not that expensive of a job you just replace the seals.
So make sure which one of the two.
THE AUTO SPECIALIST
- Mar 2006
- 607
October 24th, 2008 08:12 AM #5pag nag babawas ng coolant , head gasket or the head itself
pag nagbabawas ng engine oil , make sure the pcv system is good .
possible seals or rings
pag malakas sa gas , feedback ba ang carb?
possible sensor problem
para makasigurado ipasyal mo sa trusted mechanic
October 24th, 2008 10:05 AM #6
paki check mo muna throttle valve ng car mo baka madumi.. nagbabawas po ba sir ng langis pag check up mo po sa dipstick? para sure po sa trusted na technician po.. para hindi po masayang yung gastos po... tnx
- Oct 2008
- 469
October 24th, 2008 12:16 PM #7white smoke po lumalabas, pero hindi naman po ganun kagrabe yung pag-usok nya at hindi rin po saya nagbabawas ng Engine Oil. Tyaka medyo amoy Gas po kasi minsan. How much po kaya aabutin kung papalitan lng mga valve seals, pcv valves?? Kaya po kaya to ng shell service, gusto ko na rin sana isabay kasi sa pag Tune up and Change Oil para isang palitan nalang. Last question po, pagkano po HeadGasket and piston ring?? Tnx po sa lahat ng inputs sirs. at least medyo my cons na ko sa problem. TIA
- Oct 2006
- 60
October 24th, 2008 12:42 PM #8Before doing anything, compression test will answer most of your questions before determining what to do. Speedyfix has the equipment to do so.
- Oct 2008
- 469
October 24th, 2008 10:02 PM #9mga sir, balak ko po kasi magpachange oil and minor tune ups na rin this sunday on my sentra eccs at shell lang. Anu anu po kaya possible/important seals ang kailangan ko bilhin?? TNX.
- Oct 2008
- 469
October 24th, 2008 10:16 PM #10sir V6dreamer, anu anu po kaya seals kailangan ko po bilhin?? Kaya na po kaya ikabit ng mga taga shell service center yan??
Xiaomi E-Car
