Quote Originally Posted by Dieseldude View Post
good day to all tsikoteers. Tanong ko lang po kasi napansin ko po sa 96 Isuzu TFR pickup ko 4Ja1 ang engine following observations:
1. May lumalabas na usok sa lagayan ng oil at sa dip stick.
PCV may be blocked/restricted. Slight oil gas discharge is acceptable.
2. Timitilamsik po oil pag binuksan lagayan ng oil habang umaandar.
This is also normal.
3. parang kulay puti po usok at mabaho po amoy.
This is abnormal. Does white smoke occur only when the engine is cold, or even when the engine is at operating temperature? Are you also experiencing a rough idle condition?
Ano po kaya problema at pano solusyonan ito? Does it need overhauling? will top hauling solve it?
i hope guys you could give advice and help me with these problems. any help will be appreciated. thanks in advance.
Di kaya blowby na yan? Pakiramdaman mo kung may pagbabago ang andar. Kung masyado nanginginig. kung minsan kasi yong injector malakas na bumuga ng supply sa cylinder chamber, kaya maputi ang usok hindi nasusunog lahat ang diesel pumapasok sa loob ng cyl chamber. subukan mo buksan ang oil filler cap. kapag malakas na ang hangin lumalabas at may kasamang usok. malamang na loose compression na yan.
