Results 1 to 10 of 18
- Sep 2006
- 71
November 5th, 2006 08:38 PM #2
The 'POWER' setting just moves the shift points a few hundred RPM's higher. You can use it all the time if you want. No harm done.
November 5th, 2006 08:42 PM #3
Leaving it on just kills your fuel economy. I used to use it when going up long hills or if I had to pass someone on the highway.
November 5th, 2006 08:47 PM #4
Yup. But there's no harm in leaving it on. Especially for vehicles with low power ratings (need all the help you can get).
You can turn it to standard mode to be a bit more economical.
- Sep 2006
- 71
November 6th, 2006 01:22 AM #5Ah I see, sabi kasi ng casa sakin ginagamit lang daw yung ECT kapag naka 100rpm pataas
November 6th, 2006 11:53 AM #6
Agree with Otep. Add ko lang some details on how it works (based on observation lang po):
ECT ON:
- shift points increase depending on how hard you're pushing the gas pedal. gradual press shifts a few hundred RPM over ECT OFF, Abrupt pedal press will result to much higher shift point * ~ 4500RPM, florring the pedal results to redline shifting. Downshifting also happens earlier. Decceleration is almost always accompanied by downshifting even without pressing the brakes.
It's OK to leave 'ON' but gas mileage will be poor.
November 6th, 2006 12:00 PM #7100rpm pataas
Power mode also helps give quicker acceleration from a standing start.
December 7th, 2006 05:40 PM #8
up ko lang............ medyo naintindihan ko gamit ng ECT pero di ba pag magaan naman ang apak sa accelerator tipid pa rin sa konsumo ng gas? ung sa akin kasi nakapatay palagi ung power ECT pero gusto ko sya subukan gamitin this weekend pag-uwi ng batangas kung malakas nga ba talaga lumaklak ng gas pag naka-on o hindi.
September 14th, 2007 12:01 PM #9
our starex has an ECT, im just confused what;s the difference between "power" and "ect" coz if i press the button down it shows "power" on the dash, and if i press it up it shows "hold"
any ideas? thanks!
September 14th, 2007 12:12 PM #10
I think when you press 'hold', the transmission does not shift to the 4th gear... Let me verify that with the Starex manual.
I accidentally turned 'hold' one night and it was an ackward experience driving the van.....
3808:fish:
Tax exemption sa pickup trucks, tinapos na sa ilalim ng CMEPA law | Agenda Bilyonaryo News Channel
PH Gov't looking to bring back excise tax for...
